Help! Radix Problem
Old Jan 2, 2008 | 07:49 PM
laynlow77's Avatar
Default Help! Radix Problem
im not sure when it happened but it looks like my pulleys got messed up. as the belt goes over the supercharger and the passenger side it seems to run in the spot that it always did, but on the drivers side it is now running 1/4 inch or so different. ive changed belts, all pulleys, and even pulled off the idler spacer bracket to see if it came out of alignment. as you can see its pretty messed up and i cant see why!
any ideas?
Old Jan 2, 2008 | 08:19 PM
moregrip's Avatar
what a rush!
any ideas?
you might try taking the stock spacer off that pulley and running a magnuson spacer machined down a bit
Old Jan 2, 2008 | 08:27 PM
laynlow77's Avatar
what do you mean? this is all of the stock magnuson supplied stuff.....
even when i put the metco pulleys on it still sits sideways like that :headscratch:
Old Jan 2, 2008 | 08:29 PM
Stoichiometric's Avatar
Check your balancer and make sure it is not walking off the crank or the rubber is not tearing.
Old Jan 2, 2008 | 08:40 PM
moregrip's Avatar
what a rush!
I thought the one on the right(drivers) is the stock idler
Old Jan 2, 2008 | 08:46 PM
laynlow77's Avatar
it is, there is no spacer behind it. ill check that balancer tomorrow, so a spun crank bolt could do this too?
Old Jan 2, 2008 | 08:52 PM
XLR8NSS's Avatar
Adkoonerstrator
When my crank bolt backed out and the crank was walking it threw my belt out of alignment but, it was out equally on all pulleys. It's worth a look though. If you haven't pinned the crank you REALLY should do it.
Old Jan 2, 2008 | 08:53 PM
moregrip's Avatar
what a rush!
I thought there was a funky looking stock spacer on there, maybe I don't remember right
Old Jan 2, 2008 | 08:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
Honestly I do not see anything out of the ordinary. Where do you see the issue? The belt will walk back and forth on the idlers under different loads, so un-even wear is common.
Old Jan 2, 2008 | 09:23 PM
dewmanshu's Avatar
Moderately Differentiated
I was looking at those pics...thinking to myself...****, i guess mine is all fubar'ed.
