Heat stress cracks anyone?
Old Dec 5, 2007 | 11:57 PM
thunder550's Avatar
High on diesel fumes
Default Heat stress cracks anyone?
Pulled my manifold off tonight to check for what I thought was an exhaust leak. Turns out I was right. These cracks go clean through.
Old Dec 6, 2007 | 12:00 AM
Derek @ EDO's Avatar
FormerVendor
Damn man, That sucks!
Do you have the ability to fix it yourself?
Old Dec 6, 2007 | 12:22 AM
thunder550's Avatar
I have a buddy in town that I'm gonna have weld it up for me temporarily. I'm just gonna get kbracing96 to build a new one for me eventually.
Old Dec 6, 2007 | 12:24 AM
BlackGMC's Avatar
Resident Retard
IMO you need to expand the crack with a grinder or cut off wheel inorder to get decent pentration... But then again, what do I know...
Old Dec 6, 2007 | 12:27 AM
Bill Reid's Avatar
Weld it up with some deep power... and slap it back on
Bill
Old Dec 6, 2007 | 12:31 AM
bostinchevy13's Avatar
yup weld it up and good as new
Old Dec 6, 2007 | 12:37 AM
FormerVendor
I believe if the cracks are drilled at the ends and opened up some with a Dremel tool you can save yourself a couple hundred bucks. The welder just needs to make sure his weld penetrates.
Simply take an abrasive pad on a side grinder to smooth out the surface welds if looks would be a concern!
Old Dec 6, 2007 | 12:57 AM
BlackGMC's Avatar
Resident Retard
another piece of advice, before you take it to be welded, make sure that it is absolutley clean around the welds... Scrub it down with acetone, since it will have carbon build up and you mentioned in other threads about an oil burning problem...
Old Dec 6, 2007 | 01:37 AM
thunder550's Avatar
Thanks for the tips guys. I'll talk to him about it to make sure he's gonna do a good job. I'm not concerned with how it's going to look. I could really care less, as long as the cracks are gone.
turbo6c3
Oct 5, 2015 06:11 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
