Good place to buy zr1 map sensor?
Old Feb 27, 2014 | 04:47 PM
Gadgetized's Avatar
Originally Posted by 99ta
Do these stay in the stock intake with say 15-18# of boost without any modification?
I run one in an Edelbrock Pro Flo. I made a little bracket to cover it just to be sure. I have sold several that are used in stock intakes with no problems.
Old Feb 27, 2014 | 04:49 PM
Gadgetized's Avatar
Originally Posted by 0235SS93
Im running 9psi. My stock map is pegging at 118kpa and throws high voltage dtc's. Your sensors look like mine, but Idk if the nipple size is the same and whether or not the pins are in correct orientation.
It should work. Can you get me the part number off of the one you have?
Old Feb 27, 2014 | 05:02 PM
0235SS93's Avatar
My maggie came with a small L-shaped bracket to hold the sensor down.
Old Feb 27, 2014 | 05:04 PM
0235SS93's Avatar
Ill try to get a pn when i get to work. Its the stock map sensor for a 2011 lc9 5.3
Old Feb 27, 2014 | 07:12 PM
Gadgetized's Avatar
It looks like your sensor should be 12591290. I just ordered one to take a look at it. The only problem is that I will not be home until late on 03-09 to look at it.
The_W
Oct 28, 2015 09:00 PM
Slammed96
Jul 27, 2015 07:22 AM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
jrplz
Jul 9, 2015 12:07 AM
