Going back to stock cam?
Old Feb 13, 2014 | 10:35 AM
aQuickLS1's Avatar
You could go the the ls6 cam like said above. I haven't looked latley, but you used to be able to find them used for cheap.
Old Feb 13, 2014 | 10:44 AM
Chevy_King1500's Avatar
Originally Posted by Ferocity02
It failed HC. Lowering the timing is supposed to let the fuel and air mix for longer resulting in a hotter and more complete burn. I found a link where someone actually tested this theory (and others for passing smog) and lowering the timing gave a significant reduction in HC. At least that's the theory. I has dropped the idle timing to 12 deg when it passed the second time.
lol if they only knew, do they not pop your hood or anything?
Old Feb 13, 2014 | 11:03 AM
Vortec350ss's Avatar
Im surprised to hear you think its too much cam... you already have the springs and everything... what about a more timid custom grind?
You have 16* of overlap built into that... I'm surprised you can even hear it at idle. Is there any advance ground into it?
Old Feb 13, 2014 | 11:49 AM
goinbrokez28's Avatar
Have you looked at Crane's PowerMax LS cams? Might be what you are looking for.
Crane Cams |
Old Feb 13, 2014 | 12:25 PM
KHester84's Avatar
Just curious, with the daily driver aspect, does the cam make the truck shake too much while stopped at red lights, etc? Or poor drivability? Noise? Just curious what makes you want to change it besides smog.
Old Feb 13, 2014 | 03:29 PM
black00chev's Avatar
Slowest turbo build ever!
Damn and I thought my triple 12 seemed pretty stockish, other than the added power and chunky idle in PARK and NEUTRAL. Must be getting old? Otherwise you can't tell my truck is even cammed. Must be because of the turbo?
But as for how the idle feels, you should be able to tune and smooth it out enough.
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
