Going back to stock cam?
Old Feb 12, 2014 | 02:26 PM
Ferocity02's Avatar
Default Going back to stock cam?
I currently have a Isky 212/212 0.561/0.561 114LSA cam and have been thinking about going back to a stock cam. It's my daily driver and this cam has more lope than I anticipated, it is definitely noticeable. I do like the smoothness of the stock cam. This cam also didn't pass smog, I had to jack up the idle speed to 800rpm, lower the timing, and add denatured alcohol to get it to pass. There were no mechanical issues, and it passed with flying colors just two years before with the stock cam.
What kind of power loss and turbo spool might I expect to lose by going back to the stock cam?
Stock cam specs:
190/191 int/exh @ 0.05" duration 0.466" / 0.457" int/exh lift 114 LSA
Old Feb 12, 2014 | 03:27 PM
ZO6Ted's Avatar
Years ago I saw where a zo6 cam gave 50 hp to an early trick kit not even a 76mm I don't believe
Old Feb 12, 2014 | 03:57 PM
bud8fan's Avatar
GT2-3 idles like stock as well
Old Feb 12, 2014 | 05:36 PM
PDPERFORMANCE's Avatar
If u do pull how much will u be asking
Old Feb 12, 2014 | 10:58 PM
kelsey_canard's Avatar
I'm interested in this too. Im running the stock cam in my lq4, and wonder how much I'm leaving on the table with this cam. What did you shift the 212 at?
Old Feb 12, 2014 | 11:14 PM
Atomic's Avatar
I have a gauge for that
Which part of smog did it fail? If it was hydrocarbons you would actually want to increase timing. NOx stuff decrease timing. Denatured alcohol is also known as E85...its ethanol denatured with gasoline
Old Feb 13, 2014 | 07:02 AM
Byrdman11's Avatar
I would just it a cam that ground to pass smog. My cam idle very mild in gear, almost stock.
Old Feb 13, 2014 | 07:17 AM
Chevy_King1500's Avatar
i've got a 212/218 114lsa and am thinking about swapping to a the triple 12..
would i gain anything?
Old Feb 13, 2014 | 10:06 AM
Ferocity02's Avatar
It failed HC. Lowering the timing is supposed to let the fuel and air mix for longer resulting in a hotter and more complete burn. I found a link where someone actually tested this theory (and others for passing smog) and lowering the timing gave a significant reduction in HC. At least that's the theory. I has dropped the idle timing to 12 deg when it passed the second time.
Old Feb 13, 2014 | 10:30 AM
LS1TRUCKGUY's Avatar
i will trade ya a comp 212/218 114 lsa for that isky cam of yours. idles like stock.
