Gettin her ready, last dance soon?!
Old Mar 1, 2013 | 06:33 PM
  #61
LS1FREEK's Avatar
13 Second Truck Club
Originally Posted by GMCtrk
whats your IDC?
I didn't log it when I ran it on 14psi, I was street racing a cammed C6 Z06 lol.
Old Mar 1, 2013 | 06:56 PM
  #62
Atomic's Avatar
I have a gauge for that
My numbers are WHEEL HP!
I am assuming 30% more fuel for same power on e85, I figured that would get it close. I think you should get it on the dyno before you start buying more parts....if you could somehow log pressure before your filter that might be interesting...what size wiring did you use for the pumps?
Old Mar 1, 2013 | 07:34 PM
  #63
foose04's Avatar
My regulator is prior to the fuel rail, then 1 foot of 8an to ls1 rail, then 6an loops over to other rail. Possible issue right there?
Old Mar 1, 2013 | 07:51 PM
  #64
BlackGMC's Avatar
Resident Retard
One thing you could check real quick is to take the filters out of your fuel filter and see if that is the restriction.
Old Mar 1, 2013 | 08:00 PM
  #65
Atomic's Avatar
Ah! Put the regulator after the rail! How you have it now, all the fuel has to go through the regulator. With it after the rail, only the unused excess goes through the regulator.
Old Mar 1, 2013 | 08:32 PM
  #66
foose04's Avatar
Well I don't know if I can fix this in time lol... I just got off work and want to drink.. Any pictures on how you got your atomic?
Old Mar 1, 2013 | 08:46 PM
  #67
foose04's Avatar
From Aeromotive..
"I’m trying to plumb my stand-alone EFI regulator properly, where do I put the regulator, before or after the fuel rail(s), and what ports do I use?
The correct EFI regulator location is after the fuel rail(s) whenever possible, promoting the required fuel pressure, flow volume and velocity through the fuel rail and to the injector inlet, at all times."
I got work to do and not much time to get her done in...I don't if I can get part this late, have to make some calls to so connections,
Well Snap, still going to have a beer.
Old Mar 1, 2013 | 08:59 PM
  #68
Gadgetized's Avatar
I enter the back of my rails, out the front and to the regulator. I have always thought of the old law that as speed increases, pressure decreases. If you enter one rail loop around and out the other rail, there is 8 times the fuel passing the first injector than there is passing the last injector. Maybe I'm wrong, but that is the way I wanted my fuel system to supply fuel.
Old Mar 1, 2013 | 09:38 PM
  #69
La Chochita's Avatar
Originally Posted by foose04
Haven't heard much about your truck but a I'm damn happy to hear you have 03 with the smaller rods and made big numbers. You got a sheet as I'd say for now you are top dog sir! Any case thanks man and happy boostin.
Yea. Actually the 4.8 is a 2002 as my original 5.3 was long gone since 2005 lol...but yea..its amazing how these lil engines take a hell beating...again good luck with everything and i bet ur having lots of fun right now!!!
Old Mar 1, 2013 | 09:42 PM
  #70
foose04's Avatar
Thats a pretty sweet setup!
I'm thinkin more like this...Thanks smoke!
Originally Posted by smokeshow
