Gettin her ready, last dance soon?!
#62
I have a gauge for that
My numbers are WHEEL HP!
I am assuming 30% more fuel for same power on e85, I figured that would get it close. I think you should get it on the dyno before you start buying more parts....if you could somehow log pressure before your filter that might be interesting...what size wiring did you use for the pumps?
#67
From Aeromotive..
"I’m trying to plumb my stand-alone EFI regulator properly, where do I put the regulator, before or after the fuel rail(s), and what ports do I use?
The correct EFI regulator location is after the fuel rail(s) whenever possible, promoting the required fuel pressure, flow volume and velocity through the fuel rail and to the injector inlet, at all times."
I got work to do and not much time to get her done in...I don't if I can get part this late, have to make some calls to so connections,
Well Snap, still going to have a beer.
#68
I enter the back of my rails, out the front and to the regulator. I have always thought of the old law that as speed increases, pressure decreases. If you enter one rail loop around and out the other rail, there is 8 times the fuel passing the first injector than there is passing the last injector. Maybe I'm wrong, but that is the way I wanted my fuel system to supply fuel.
#69
Yea. Actually the 4.8 is a 2002 as my original 5.3 was long gone since 2005 lol...but yea..its amazing how these lil engines take a hell beating...again good luck with everything and i bet ur having lots of fun right now!!!
