Gettin her ready, last dance soon?!
#73
My connections worked out, got some parts at 11PM on a friday lol. The swap/fix was simple, went with Atomic's routing. It worked out that I added that inline fuel filter, had some extra line to reach the back of the rail. Also found a hidden restriction fitting the feed line from the tank hooked into, this couldn't have been helping my cause.
Looks 8an...
Negative..
Only thing that had me worried was this damn plate behind the manifold blocking me at the rear of the rail, luckily the thing was held on with one bolt but was a PITA to reach. Good weight reduction mod for 9s..
Little late to fire her off for all my neighbors. I'll do a few pulls tomorrow before going to the dyno to make corrections. Still got plugs to swap in tonight and a few more beers to take care of.
Looks 8an...
Negative..
#74
I believe your issue has been likely taken care of with the adjustments you have already made. However, I do know that one of the fastest trucks in the nation was having issues with idc, when he swapped from stock ls2 rails to a larger set of aftermarket his idc went down dramatically. I am not sure this is even a factor for you at this point, but something to keep in mind if your issue does end up persisting.
#75
if your still having problems after this i got custom made fuel rails from hogans racing manifolds. think i had to ship him my stockers and he made me some 10 an logs capable of supporting 1500 hp.. the inside diameter of the logs is bigger than my thumb.. easy mod for $300.00
