Fuel pressure gaguge needed for turbo ?
Going with 4psi boost for now on my 03 silverado with a 4.8. Is a fuel presure gauge really necessary ? I have my AEM wideband and trans temp gauge installed already.
Fuel demand increases a lot with any form of FI. If your fuel system can't keep enough fuel at the rail, you want to know. So I always recommend a fuel pressure gauge. Nobody ever leaves their setup at 4-5 psi for very long....
Or you can roll the dice. Your pistons will tell you when you're fuel system is failing.
Yes you are going to want a fuel pressure gauge, You need to catch a problem before it hurts the motor and being that a fuel pressure gauge is like 60$ its kind of silly not to run one. I run fuel, wideband and boost/vac on my boosted SS, Its cheap insurance.
Yes, the fuel gauge is a must do. Like already said you will not stay at 4lb of boost. I was just wanting a stock truck with 500plus rwhp. Now, Im on a built engine,difference trans, bigger turbo, etc, etc, etc...
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
