Fuel pressure gaguge needed for turbo ?
Old Nov 24, 2013 | 07:25 PM
BlackRCSB's Avatar
Default Fuel pressure gaguge needed for turbo ?
Going with 4psi boost for now on my 03 silverado with a 4.8. Is a fuel presure gauge really necessary ? I have my AEM wideband and trans temp gauge installed already.
Old Nov 24, 2013 | 07:33 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Fuel demand increases a lot with any form of FI. If your fuel system can't keep enough fuel at the rail, you want to know. So I always recommend a fuel pressure gauge. Nobody ever leaves their setup at 4-5 psi for very long....
Or you can roll the dice. Your pistons will tell you when you're fuel system is failing.
Old Nov 24, 2013 | 08:01 PM
BlackRCSB's Avatar
I guess I'll be looking at some lol
Old Nov 24, 2013 | 08:05 PM
BlackGMC's Avatar
Resident Retard
Is a condom needed with a hooker ? I say, YES!
Besides you gain 10hp with every gauge. I currently have 7 gauges in my truck.
Old Nov 24, 2013 | 09:45 PM
N20zuki's Avatar
Is a condom needed with a hooker when you plan to pull out would be better said lol...
Yes you are going to want a fuel pressure gauge, You need to catch a problem before it hurts the motor and being that a fuel pressure gauge is like 60$ its kind of silly not to run one. I run fuel, wideband and boost/vac on my boosted SS, Its cheap insurance.
Old Nov 24, 2013 | 10:24 PM
Byrdman11's Avatar
Yes, the fuel gauge is a must do. Like already said you will not stay at 4lb of boost. I was just wanting a stock truck with 500plus rwhp. Now, Im on a built engine,difference trans, bigger turbo, etc, etc, etc...
Old Nov 24, 2013 | 10:48 PM
Ferocity02's Avatar
I use an autometer fuel pressure sensor and wired it into the EGR signal so I can log it with EFILive. Also, the wideband will show lean if the fuel pressure drops.
Old Nov 24, 2013 | 10:50 PM
GMCtrk's Avatar
FP gauge is not a necessity.
Old Nov 24, 2013 | 11:33 PM
oakley6575's Avatar
Best comment!
I would run the FP gauge. No reason not to imo.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
