Front mount guys, I need info
Old Dec 28, 2010 | 10:41 PM
  #31
kalikid06's Avatar
BTW, how big of a turbo can I use with a 3" downpipe?
Old Dec 28, 2010 | 10:53 PM
  #32
charcold-bowtie's Avatar
I would say relatively, any big t-4 like the 88mm, and all the t-6 would probably need 4 inch or bigger.
I would think 76 and down would be fine with a 3, or even 3.5.
If you buy it from kyle or trick it should be appropriately sized
Old Dec 28, 2010 | 11:06 PM
  #33
Bill Reid's Avatar
IMO, I'd start looking at a bigger down pipe after a T76. With a T76 you can go with an F1 wheel (S Trim? from Turbonetics) same as me and play with your exhaust housing A/R to get it to hit where you want depending on your CI. I am running a T66 with a large F1 wheel in an .81 housing with a stock 5.3L. With a 3200 stall and a home built 4L80E I am happy. Big question is matching cubic inches with the turbo, your driving habits, your anticpated operating range, and the assumption it will be street driven... perhaps daily driver(?). IMO, bigger down pipe wouldn't even begin to come into the picture until you plan on a 10 second truck... (emphasis) and not until then. A repeating factor, again, is drivability.. and how it sounds inside the cab. Some systems are extremely annoying... others can be too quiet. There are so many factors...
Old Dec 28, 2010 | 11:13 PM
  #34
kalikid06's Avatar
The plan is an LQ4 with a Master Power T76 at 12, maybe 13psi. Yes, it will be a daily driver but the fastest I'd shoot for would be somewhere in the 11's.
Old Dec 30, 2010 | 09:53 AM
  #35
Banned
Originally Posted by tarinitup
No check engine light but the low fuel light drives me nuts after fuel cell.
you can call autometer and they can calibrate the sender in your fuel cell to work with the stock dash.
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
