Front mount guys, I need info
Old Dec 27, 2010 | 08:25 PM
kalikid06's Avatar
Default Front mount guys, I need info
Just a quuick question about the 02 sensor situation with a front mount. I've seen so many people with ORY's and front mounts driving around with their check engine light always on. I know that the cats go away with a front mount install but is it possible to keep that damn check engine light from staying on with a front mount? I'm assuming it can be taken care of with the tune but I honestly don't know. I would go insane driving around with nothing wrong and have the check engine light always on. Thanks in advance.
Old Dec 27, 2010 | 08:28 PM
blue0453's Avatar
My engine light is never on. The cats are deleated out of the tune.
Old Dec 27, 2010 | 08:32 PM
kalikid06's Avatar
THAT is what I wanted to hear, thanks. BTW, how do you like your KBracing kit? I'll probably be getting his hot pipes soon.
Old Dec 27, 2010 | 08:52 PM
blue0453's Avatar
No problems so far. Been running it for about a year. Kyle is a real good/knowlegable guy. Good luck with your install, let me know if there is any thing I can help you with. Nick
foose04's Avatar
Also in the no check engine club with no cats.
Old Dec 27, 2010 | 08:55 PM
tarinitup's Avatar
9 Second Truck Club
No check engine light but the low fuel light drives me nuts after fuel cell.
Old Dec 27, 2010 | 09:02 PM
kalikid06's Avatar
Thanks for all the info guys. Oh, and where on the oil pan is the best place to put the drain?
Old Dec 27, 2010 | 09:09 PM
smokeshow's Avatar
Mod with training wheels
Mine is in the front of the pan just behind the crank pulley. It really doesn't matter where, as long as its out of the way and doesn't interfere with anything inside the pan.
Old Dec 27, 2010 | 09:43 PM
blue0453's Avatar
Mine is on the pass side of pan about an inch above oil level sensor.
Old Dec 28, 2010 | 02:19 AM
99LsSilverado's Avatar
My thought about the oil return line should be high in the pan like where blue said his is so you dont have an issue with draining against the pressure of the oil in the pan
