Front mount guys, I need info
Old Dec 28, 2010 | 02:27 AM
Daryn's Avatar
Formerly darynC-10/23/10
i have a bung welded in above the oil level sender
Old Dec 28, 2010 | 05:40 AM
slowec's Avatar
We need some pics of these return lines and where to put em in the pan. There might be a few front mounts going in SOON !
Old Dec 28, 2010 | 07:35 AM
THE-HOE's Avatar
Mines also in the pan about as high as i could get it on the passenger side above the oil level sensor. I almost wish that i would have put it right into the front of the pan though.
Old Dec 28, 2010 | 08:59 AM
Atomic's Avatar
I have a gauge for that
Old Dec 28, 2010 | 09:30 AM
blue0453's Avatar
Originally Posted by 99LsSilverado
My thought about the oil return line should be high in the pan like where blue said his is so you dont have an issue with draining against the pressure of the oil in the pan
The return must be above oil level in the pan or you are gonna have problems.
Old Dec 28, 2010 | 10:58 AM
kalikid06's Avatar
So, just mount the drain as high on the oil pan as possible? Would that be high enough?
Old Dec 28, 2010 | 12:58 PM
Atomic's Avatar
Where I put mine is right above the oil level, and far enough below the starter to run the hose...I got lucky on that one since I didnt plan for either
Old Dec 28, 2010 | 02:27 PM
foose04's Avatar
Always here to help a fellow turbo guy out! Mines mounted under crank pulley, as high I could get it. Also worth noting I did mine with oil pan installed, just used the grease and bit drilling style. Took my time and kept 8lb 6 ounce baby jesus in mind as I slowly drilled.
Old Dec 28, 2010 | 03:48 PM
99LsSilverado's Avatar
that is exactly what i had said in my post where above the sensor is a good place to put it
Old Dec 28, 2010 | 04:40 PM
Bill Reid's Avatar
Here's mine ...
