Found the oil burning culprit finally :)
Old Jul 25, 2008 | 02:18 AM
Spoolin's Avatar
GFYS and STFU
Slap that bitch on there and give her hell!!!
You gonna use your roomates turbo for a little while? That things seen the last of it's useful days! Make a blender out of it or something!
Old Jul 25, 2008 | 02:24 AM
thunder550's Avatar
High on diesel fumes
I was gonna put Mike's turbo on today, but his compressor housing has a 2" outlet instead of the 3" that I need.
Old Jul 25, 2008 | 02:28 AM
Spoolin's Avatar
GFYS and STFU
Ouch...that's gonna hurt up top! how's your A/R housing look? swap that onto the new turbo!
Old Jul 25, 2008 | 10:16 AM
thunder550's Avatar
I tried putting my compressor housing on his turbo but it won't fit. Mine's a Precision and his is a Turbonetics
Old Jul 25, 2008 | 12:27 PM
WJ MARK's Avatar
I would make a leaf blower attachment with that for your lawn mower, lol.
Old Jul 25, 2008 | 12:34 PM
PappyDan's Avatar
Tribe Shaman
well i would try to clean it up some, slap in a new seal kit.
and build my own jet engine with afterburner.
Old Jul 25, 2008 | 01:25 PM
thunder550's Avatar
Got a line on a new Garrett 4202R turbo...should find out on Monday if I'm gonna get it
Ball bearing, 1.15 a/r turbine housing, 74.7mm.
Old Jul 25, 2008 | 01:39 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by thunder550
Well, after chasing an oil burning problem ever since I first installed the turbo kit on my truck, I think it's finally shown itself.
Looks to me like when I lost #7 on the last motor it threw some crap through the turbine wheel on the turbo. The edges are pretty chewed up. I'm also thinking that when that happened, it threw the wheel enough out of balance to slowly wear on the oil seal until it started smoking all the time.
I'm gonna take this down to the local turbo expert tomorrow and see if he can rebuild it for me.
Looks like you burned it up I doubt that is from debris.
Old Jul 25, 2008 | 01:41 PM
thunder550's Avatar
How do you burn up a turbine wheel? I thought the only thing that would potentially fry were the bearings?
Old Jul 25, 2008 | 02:41 PM
vanillagorilla's Avatar
Check your housing too. The turbine may have contacted it while it was out of balance. I had turbo do that, and it chewed up the housing. It's cheaper and easier to get a new turbo sometimes. I still haven't found out why mine did that either. I doubt it's from your #7 though since you had oil burning issues when the engine was healthy. I just think precision turbos has shitty quality control and this is the result. It got out of balance and started contacting the housing. That ore it got too hot, and then started into the housing.
