Flewbyu’s rode to 1200rwhp.
Old Dec 25, 2020 | 11:45 AM
Flewbyu123's Avatar
Default Flewbyu’s rode to 1200rwhp.
I started my new build during the beginning of the pandemic. I did a few things a couple of years back and ultimately was dissatisfied with the outcome due to lack of actual candor of the engine I purchased from a party out of state. So to make sure this time I wanted to do the work myself not something I’m normally not doing but I’ve done some things before as a teenager on engines. Therefore I am always open to suggestions from people with a little more knowledge. I am an electronic technician by trade. So some of the wiring stuff comes a little more easier to me. Here is the list a parts and things I have so far.2005 LQ4 block 0.30 Over bore
Manley forged pistons 4.030
Eagle Forged Rods 4340 ARP 2000 7/16
ARP 234-5608 Main bolts
Lunati 4.000 24T Forged Stroker Voodoo Crank
Double roller billet roadmaster timing chain w/ Torrington Bearing /ARP Bolt
Melting Oil pump 10355
ARP 234-4317 Head studs
LS3 CNC 320cc Heads 260cc/64cc
Lunati Voodoo blower cam 2054LS3S3 233/250 618/595 113+5
Ultra pro magnum XD roller rocker arms 1.8
Johnson Bar Link Lifters ST2116LSR
LS9 Head Gasket
Manley 25767-16 Chrome Moly .080 Wall 5/16 Pushrods 7.600
King Racing CR 807XPN
King Engine Bearing MB5013XP Main Bearing
ATI Super Damper 918635 harmonic damper
Procharger F1A-94 W/3 core intercooler
3 bar map sensor
Holley LS3-L92- 105mm Hi - Ram Black Intake
Holley Injectors 160lbs 522-168FM
AEM Water/Methanol Injection Kits 30-3300
Old Dec 25, 2020 | 11:52 AM
Flewbyu123's Avatar
Default A few photos
A fresh start
Back from the machine shop
Time to go to work
Old Dec 25, 2020 | 11:59 AM
Flewbyu123's Avatar
Default More photos
The color I chose
The color I chose
Old Dec 25, 2020 | 12:07 PM
Flewbyu123's Avatar
Default Photos
Stroker crank
Old Dec 25, 2020 | 12:13 PM
Flewbyu123's Avatar
Default Even more pics
Had the machine shop put the rods on the piston only to later find out they had numbered them all wrong
Cam is in
Old Dec 25, 2020 | 12:36 PM
Flewbyu123's Avatar
Default Still more
Number one piston up
After I learned they were numbered wrong
Getting it all lined up
Old Dec 25, 2020 | 12:59 PM
Flewbyu123's Avatar
Default And even more
Getting everything lined up of course had to change a few things because the crank was hitting
Oil pump
Oil pump tube clamp
Old Dec 25, 2020 | 01:04 PM
arthursc2's Avatar
GM makes a windage tray for 4.0" stroke motors, I used it in my 408 as well!
I also did the pick-up tube clamp
what are you gonna rev to?
Old Dec 25, 2020 | 01:06 PM
Flewbyu123's Avatar
Default Few more
Slowly but surely going back together
Old Dec 25, 2020 | 01:18 PM
Flewbyu123's Avatar
Default More
Add to re-order Ls9 gaskets Tried a cheaper pair off of eBay they look the same but I had to replace them if it was not good
Water pump installed
Finally getting the lifters installed after the porch thieves got a hold of my first set and delaying me even more
