Finishing up my Radix install. Few questions
Old Dec 28, 2005 | 03:11 AM
BLASTER's Avatar
Some pics.....
Plum Crazy Purple....
Old Dec 28, 2005 | 03:14 AM
BLASTER's Avatar
After everything is verified with the Blower
these and Cognito leveling kit are going on next.
Old Dec 28, 2005 | 11:20 AM
BLASTER's Avatar
One more thing...
Magnasum recommends stock plugs for gap & heat range. So I am assuming my NGK IRX will be OK gapped @ 0.57?
I would like to get colder plugs, what is recommmended?
Old Dec 28, 2005 | 11:50 AM
BlownChevy's Avatar
blownerator
25 Year Member
Make sure that harness is not in the way of the bypass actuator.
Old Dec 28, 2005 | 01:46 PM
LVSTOGOFST2002's Avatar
Originally Posted by BLASTER
-Almost put the blower on without noticing blocking the two rear coolant vent holes; no instruction to do so.
um, did i not do this?
Old Dec 30, 2005 | 01:54 AM
BLASTER's Avatar
Blower is on.
Started it up and had a ticking noise. Sounded like something was hitting the belt so I shut down and checked everything. Tightened the fule lines cause I saw leakage. Fired it up again and checked all the injectors & plug wires & it is pretty quiet.
All in all, I would say I was relieved. Sounds good when I give it some part throttle and get up above 2K. You can really hear the blower whine. I love it. If I drive normally I can't even tell its there. Doesn't seem that much more powerful or faster but my butt-o-meter was never really accurate.
One thing I do notice is a smell afterward (post shutdown).
Does the blower/engine give off aburnt smell for a while?
Like the oil from your hands and stuff burning off of something?
Is there a break in period for the blower?
I have not give a real WOT run since it was wet out today. Hopefully I can hook up my guages this weekend to get some feedback on boost fuel, & coolant.
What should I do to make sure I did everything correct? Thanks
EmmerichLSx
Sep 14, 2015 09:47 AM
Sevex
Aug 22, 2015 12:12 AM
89sierra
Aug 19, 2015 07:13 PM
USMCvet0311
Aug 1, 2015 07:45 AM
KyleW707
Jul 29, 2015 08:17 AM
