FI war
Old Oct 8, 2006 | 12:20 PM
  #31
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by nightrunner
thanks
slow:
its not the fact of rounding up parts for the sts cause thats not a problem i just dont trust the location of the system from the standpoint of protection from rain this will be on an every day driver and i want to basically bolt the kit on an forget about it so to speak ive heard stories that if you get into boost while its raining or something youll suck water in your intake even if its relocated - not happening for me if i want to get into boost i want to be able to and not have the weather tell me that i cant
Why dont you ask the guys up north running the STS kit
Not to mention dude you are 2wd on a wet road if you punch it you are going to be in the ditch period no matter what system you buy.
Old Oct 8, 2006 | 12:21 PM
  #32
nightrunner's Avatar
Mr. Obvious
Originally Posted by MrXerox
Boost and wet roads are not gonna jive no mater what kit you go with
i knew somebody would say that
im thinkin either the radix or the livernois
does anybody know what has to be modified on the livernois kit to fit the larger turbo(gt67 or gt76) in their kit it says on their site that any turbo upgrades to basic kit may require modification
Old Oct 8, 2006 | 12:28 PM
  #33
1slow01Z71's Avatar
You going with a bigger motor? The lviernois kit isnt available at the moment.
Old Oct 8, 2006 | 12:39 PM
  #34
Mr. Obvious
are they on back order?
yea i plan on a 408 after i boost the 4.8/5.3 and on the 408 i want either livernois gt76 or mp122hh but with 2wd im goin to have to figure out something about the torque that a 408/mp122 would have
i dont actually have this truck yet just asking questions but im trying to find the truck with the right options
Old Oct 8, 2006 | 12:51 PM
  #35
XLR8NSS's Avatar
Adkoonerstrator
Even with AWD traction in the rain has become somewhat tricky with the radix bolted on.
So what are the final goals for your truck? I've seen a lot of different stuff posted here. Just from my own personal experience if you don't have a solid goal you'll end up spending more time and money redoing things as your mind/goal changes then if you have a definate plan to start with.
Old Oct 8, 2006 | 01:03 PM
  #36
Mr. Obvious
i want a solid dependable daily driver that is moderately quick for now and then when i get the money build a 408 and drop iit in there and with some sort of FI get into the high-mid 11s(capable) daily driven
i dont want to go under a 11.5 cause that is when you need a cage and im not going to do that
Old Oct 8, 2006 | 01:10 PM
  #37
04Denali's Avatar
I agree with this statement more than you will ever know.
A year ago May I bought my truck and within a couple of months put the Radix on thinking that was all I was going to do, NOT, I got the mod bug and as soon as I heard of something else that would give me a few more ponies I would run out and buy it, Like E-fans, 1.85 rockers 90mm TB conversion and so on, Just check out my sig. everything was done piece by piece, than came the wide band and logging software, After more money than I care to think about it still isn't enough, So I took a step back and and thought about what I wanted,
I am not going to sit here and list what I have decided this is not my thread and I won't High Jack it, But what I am getting at is make sure you think about what you want or you will waste 10 or 20 grand, and still be doing it all over again.
Mark
Old Oct 8, 2006 | 01:28 PM
  #38
XLR8NSS's Avatar
Adkoonerstrator
I don't think you'd have to even worry about a 408 for that. I think you could do it pretty easily with a basically stock 6.0L and whatever form of FI you decide on.
My truck is about 1000lbs heavier than the truck you are looking for. If you take my engine/radix setup and put it in that truck you're looking at low 12's right there. Throw a cam and converter in there and that is your 11's truck....as long as the suspension/tires are up to the task.
Old Oct 8, 2006 | 01:33 PM
  #39
Mr. Obvious
could it (11.9) be done with a 408 N/A
Old Oct 8, 2006 | 01:45 PM
  #40
XLR8NSS's Avatar
Adkoonerstrator
Yes, with some of the awesome heads and 90mm intakes available today I think 11's could be done in a rcsb 2wd truck without much hassle.
