Exhaust size
Old Jun 12, 2018 | 12:19 AM
engineer478's Avatar
Default Exhaust size
I have 1 3/4 headers on the truck, into a single 3 inch. The mods are TFS 205s, 216/218 .560 114 cam and Kenne Bell charger @9psi . What type of power if any is being left out? I would like to go duels but what size, bigger Header? I Know the cam is not perfect, but I have a 6.0 block just waiting, to see if it goes in the truck or maybe an F body.
Thanks, Bill
Old Jun 12, 2018 | 09:12 AM
Littlefield's Avatar
I’m curious as my 2016 5.3 is similar. If you look at the recommendations it should be dual 3”.
Old Jun 12, 2018 | 12:16 PM
BudRacing's Avatar
The merge to 3" is the greater restriction. The upgrade to 1 7/8" primaries probably won't yield the power gains to justify the price. A dual in/out straight through muffler (magnaflow, borla, or similar) will be the easiest way to free up the flow. 2.5" or 3", either will be an improvement.
Old Jun 12, 2018 | 01:27 PM
I forgot to mention It has a Magnaflow cat back.
Old Jun 12, 2018 | 02:16 PM
kaze_v8's Avatar
So for power gains wise, go with a dual over a Y then, correct?
Had a good deal on some headers and Y, but if performance wise True duals are the answer, then id rather go that route.
Old Jun 12, 2018 | 04:59 PM
BudRacing's Avatar
I'd probably go with this:
https://www.speed-engineering.com/sh...universal.html
And I'd go with one of the brands mentioned as speed engineering muffler offerings are pretty loud. But of course, muffler selection for tone and volume can be left up to you. The true dual setup won't be a worry in the future if and when you upgrade to more cam/displacement.
Old Jun 13, 2018 | 12:12 PM
TXsilverado's Avatar
throw in a dual 3" with an H pipe and call it done. the theory behind an X pipe doesn't make as much sense when you're forcing air in/out of the engine. N/A or Nitrous I would be inclined to suggest a X pipe.
Old Jun 13, 2018 | 01:39 PM
skolman91's Avatar
X2
Find a way to add another 3” pipe for duals and will be plenty for a mild setup not going for all out, decent 3/4” headers can make plenty of power with the rest of the exhaust fairly open.
MOBBN
19
Sep 27, 2015 11:26 PM
LS1TRUCKGUY
Nov 24, 2013 07:40 AM
fixinitup
Jul 27, 2007 03:44 PM
xdanny510x
Jan 31, 2007 06:35 AM
