Exhaust housing to big, i have an idea.
Old Oct 23, 2012 | 06:54 AM
bk_cauley's Avatar
Default Exhaust housing to big, i have an idea.
Quick run down. Rear mount setup with an VsRacing gt45. it has a 1.15 ar exhaust housing. doesnt spool until 3-3500. Im thinking about making my own gasket and Cutting off half of one of the openings. It is a dual scroll turbo. Anyone think this will help spool it faster? and if im not making myslef clear LMK and i will draw a picture.
Old Oct 23, 2012 | 08:11 AM
sprayedenali's Avatar
Essentially making a quick spool valve that never opens... Give it a try and see what happens. Worse that could happen is it doesn't work as you open up the other side too
Old Oct 23, 2012 | 08:49 AM
M&M Turbochargers's Avatar
u could try wrapping your exhaust it will keep the heat contained better ,causing better spool (maybe a couple hundred rpm ) allot of guys run that turbo as a front mount
Old Oct 23, 2012 | 08:55 AM
bk_cauley's Avatar
Just got a gasket made. no change. i wonder what would happen if i blocked an entire opening off. im only on 6 psi. no real big power. engine is 100% stock other than injectors. i think im gonna try it and see. gotta find another license plate to hack up. which one should i block? inner or outer?
Old Oct 23, 2012 | 09:07 AM
Ya, try wrapping your exhaust before the turbo as much as possible.
Also getting a good converter and cam/springs will help your spool time significantly
Old Oct 23, 2012 | 09:40 AM
bk_cauley's Avatar
I will buy a different turbo before i buy a convertor/cam/srings.
Old Oct 23, 2012 | 09:41 AM
bk_cauley's Avatar
on a serious note would it matter which side of the scroll i block off?
Old Oct 23, 2012 | 10:25 AM
slow67's Avatar
Gingervitis Addict
Why don't you try both? I've been told if you block off the side farther from the center section, it works better.
Old Oct 23, 2012 | 10:41 AM
bk_cauley's Avatar
Okay guys, here is what i got.. i totally blocked off the inside runner and spool went from a pretty consistant 3500 to 2800. Not real sure how back pressure looks yet. but power feels good. When i get back from lunch im gonna flip the gasket and see if that makes a difference.
Old Oct 23, 2012 | 12:20 PM
Ferocity02's Avatar
It should spool faster if the exhaust is going into the turbine farther from the center. Farther from the center means a longer moment arm and thus more torque rotating the turbine.
This gasket you made, is it literally gasket material? If so, I don't think it will last very long hanging out in the exhaust path. It would be better to make one from steel, at least 1/8" thick I'd guess.
And as mentioned, wrapping your exhaust should help a bunch. Turbos extract heat and velocity from the exhaust. The cooler the exhaust is when it reaches the turbo the less of both you will have.
