Excessive turbo smoke!!! Need help please
Old Feb 10, 2017 | 11:46 AM
  #31
TrickTurbo's Avatar
Truck Sponsor
We have 100's of these oil
Kits out there. Been running that combination for years.
The 5/8 hose barb Has the same id with 1/2npt or 3/8npt.
Now unless the fittings where machines in error then they aren't the issue.
Old Feb 10, 2017 | 12:33 PM
  #32
Also looks to me as if the drain starts going back uphill about 8" from the pan....
Old Feb 12, 2017 | 02:56 PM
  #33
MrHorsepowerLSx's Avatar
11 Second Club
Update, Rick and the others nailed the drain hose as an issue, it did go uphill a bit, I took a side shot as recommended. That helped the issue 95%.
When I hook up the "vent" hoses into the PCV it builds backpressure almost instantly and will begin to blow blue smoke, nothing like in the first video, but if I let the valve covers vent to atmosphere all together the smoking stops almost immediately.
How are you guys venting the PCV system?
Old Feb 12, 2017 | 06:02 PM
  #34
Atomic's Avatar
I have a gauge for that
I vent both valve covers to a vented catch can.
  #35
TrickTurbo's Avatar
Truck Sponsor
If you are using a Pcv you need a check valve in the line.
No Pcv vent the valve coves to filters or a catch can with filter.
Old Feb 13, 2017 | 11:52 AM
  #36
11 Second Club
Do you have both covers going to one catch can?
Old Feb 13, 2017 | 12:39 PM
  #37
Atomic's Avatar
Yes. When I had the turbo I also had the valley going to it as well. 1/2" lines from each valve cover to a moroso vented can. One line on each side.
Old Feb 13, 2017 | 04:18 PM
  #38
11 Second Club
Ahhhh I see, did you drill/tap the valve covers for the larger dia. Hose? Or just shove the 1/2" hose over the factory nipple
Old Feb 13, 2017 | 04:21 PM
  #39
ezdaar's Avatar
your problem maybe resolved. but this popped up on my radar today, figured you guys might gleen some info.
Oil drainback and windage.. - Yellow Bullet Forums
Old Feb 13, 2017 | 06:51 PM
  #40
Atomic's Avatar
On the driver side I drilled and tapped it for 3/8" npt and used a 1/2" barb. Pass side is stock I think.
