engine question
Old Mar 30, 2009 | 09:30 PM
blander66's Avatar
Default engine question
I am starting to gather parts to swap a whipple charger that i got for cheap onto my truck. I am planning on swapping the cam when i do the blower, i have one of thunder racing blower cams. that has the specs 214/230 .601/.579 117LSA. I am planning on also upgrading the springs and pushrods any ideas? Any thing you think that i am missing that is critical?
Old Mar 30, 2009 | 09:34 PM
95 bright teal's Avatar
What injectors do you have? and who does your tuneing?
Old Mar 30, 2009 | 09:39 PM
blander66's Avatar
60 lb mototrons, I have a copy of Hp tuners so i am going to run there 2 bar speed density tune
Old Mar 30, 2009 | 09:41 PM
Are you running a stock fuel pump?
Old Mar 30, 2009 | 09:54 PM
blander66's Avatar
I am running a GM pump for a TPI car, i have this motor in a old truck. I am using a 2002 vette filter that makes it a return less system
Old Mar 31, 2009 | 12:04 AM
Rick_Vor's Avatar
You can put a fuel pressure guage on it to be sure but I thought the TPI cars ran about 38 PSI. You will probably need to move up to one of the Walbro 255lph pump's to get the pressure up.
Rick
Old Mar 31, 2009 | 10:20 AM
blander66's Avatar
Rick
The pump puts out more than that they just regulated it. I have a vette filter so i run at a constant 58 PSI. Is that going to be ok being that the filter will not raise pressure with boost?
Old Mar 31, 2009 | 10:35 AM
kbracing96's Avatar
Yes, you just have to run a sloped IFR table like the f-bodys and Vettes do and tune for boost accordingly
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
