Engine Oil with Turbo
Old Apr 8, 2012 | 09:09 PM
Ferocity02's Avatar
Default Engine Oil with Turbo
Out of curiosity, is there a need to use a special/different oil with an oil-cooled turbo? I've mostly used Valvoline 10W-30 or 40. I have also used Valvoline Max Life, Mobil 1 Clean 5000, Castrol 5W-30... pretty much whatever is on sale. I think they have all be conventional however.
While my truck is not turbo'd right now, I need to change the oil this month and it will be turbo'd before the following oil change. The plan is a KB intercooled kit with a MP70 to start, upping to a 76mm probably soon.
Should I consider using another kind/weight of oil? Would be be bad to change to synthetic now? It has 101k miles on it. Front main seal was changed 10k miles ago, rear main seal will be changed in a couple weeks. Original pan gasket. No oil leaks to speak of right now.
Thanks!
Old Apr 8, 2012 | 10:11 PM
dmelvin's Avatar
I'd go ahead and switch to synthetic. Just check your oil more often for the first couple thousand miles to be sure it's not going though more oil than usual, if it uses any as of now at all.
Old Apr 8, 2012 | 10:21 PM
Atomic's Avatar
I have a gauge for that
You should really run a racing type oil due to the heat produced from a turbo. Brad Penn or Valvoline VR1 are good choices. Basically something with a lot of zinc in it.
Old Apr 8, 2012 | 11:43 PM
14psisupra's Avatar
Iv been running rotella
Old Apr 9, 2012 | 05:00 AM
JoeyGC5's Avatar
Rotella 15w-40 and I change every 2k miles.
Old Apr 9, 2012 | 08:09 AM
xx_ED_xx's Avatar
I would run at least a synthetic. My turbo is off of a throttleless diesel so it doesnt like a ton of oil pressure. Which my bbc makes. They do make a lighter weight diesel oil.
Old Apr 9, 2012 | 08:14 AM
JFOLM's Avatar
Do you use a restrictor?
Old Apr 9, 2012 | 05:43 PM
joeyc125's Avatar
11 Second Truck Club
I run rotella 5-40 synthetic. It's made for turbo engines and high heat.
Old Apr 9, 2012 | 05:51 PM
black4.8's Avatar
valvoline vr1 10-30 and change it every 1000 miles
Old Apr 9, 2012 | 05:57 PM
graysilverado5.3's Avatar
Anybody run the amsoil racing oil?
