Edelbrock E-Force
Old Mar 5, 2010 | 01:07 PM
DiggityDave's Avatar
Default Edelbrock E-Force
I have a 2001 6.0L silverado and was wondering if the e-force would work on the truck.
Old Mar 5, 2010 | 01:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Since it is set up for a Corvette / Camaro....NO it will not work.
Old Mar 5, 2010 | 01:40 PM
ForcedTQ's Avatar
An entire front accessory drive system change-out would have to be done to run it. Otherwise the snout pulley will not line up correctly, and the water pump will interfere with the TB/Intake tube.
Old Mar 5, 2010 | 01:41 PM
BlownChevy's Avatar
blownerator
25 Year Member
Why wouldnt you install the Magna Charger that was designed for the truck?
Old Mar 10, 2010 | 07:58 PM
Well i have a whipple but I'm looking for something that can huff and puff a bit more. And from what I have read the edelbrock e-force is pretty much the same as the zr-1's blower.
Old Mar 10, 2010 | 09:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
Again, why wouldnt you get a Magna Charger that is DESIGNED for your truck.
Old Mar 11, 2010 | 10:23 AM
OnyxSilveradoSS's Avatar
what he said!
Magna charge has a truck acc drive, 2300...its not as complete as the 1900 kit but it will be alot easier than try to use the Edelbrock unit.
Old Mar 12, 2010 | 01:57 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by blownchevy
again, why wouldnt you get a magna charger that is designed for your truck.
+1111111111111111111111111111111111111111111111111 1111111111111111
Old Mar 12, 2010 | 02:09 AM
00Silv4.8's Avatar
Old Mar 12, 2010 | 08:54 PM
old motorhead's Avatar
Not sure DiggyDave is aware that Maggie, ZR1, and E'brock use the same EAton TVS blower guts.
lsxperformance
Apr 20, 2016 12:17 AM
turbo6c3
Oct 5, 2015 06:11 PM
cousblake11
Sep 9, 2015 06:52 PM
Sevex
Aug 22, 2015 12:12 AM
