E85 and me...
Old Jun 18, 2008 | 07:40 PM
Lord Aries's Avatar
Red face E85 and me...
OK guys, forgive my stupid questions on this because i;ve been out of the loop for a while...
My truck is non-flexfuel 2003 Avalanche, i've got a Livernois intercooled Front mount turbo set up running 10lbs of boost and 44lbs Marine injectors from the 8.1L (included with turbo kit). Other then that the motor is all stock. Custom Dyno tuned.
Can I run e85 in my truck with my current set up? I've read about tuning issue on the Flexfuel trucks where they have to know what fuel is in the tank but, is this a problem on a set up like mine? Do I need to change anything about my fuel system? Maybe add a meth kit?
If I can run e85, can i freely switch back and forth from e85 and 93 octane gas on the fly? like if on a road trip and can't find e85...
i know these are probly noob wustions but, like i said i've been out of the loop for a while... But at $112 per tank it would be nice to save some money, even if just a little here and there.
Thanks guys
Old Jun 18, 2008 | 08:15 PM
shakinlm7's Avatar
you'd have to tune to run e85 than switch your tune back when ever you want to run regular petro
Old Jun 18, 2008 | 08:22 PM
parish8's Avatar
single digit dreamer
e85 wont save you any money since you will use ~30% more of it than reg gas.
no you wont be able to swap from one fuel to the other unless you have that special sensor and the tuning to go with it.
your fuel pump and injectors may not be large enough to run e85
there are some concerns that parts of the fuel system may not hold up to e85 but i think you would be ok there.
just my $.02 but e85 doesn't make any sence even ifyou have a flex fuel vehicle. not from a money stand point or an enviromental standpoint. BUT for a turbo set up it does make sence to me if you can use the extra octane. not sure of the limit but you would be able to run a few more lb's of boost than you do now from switching from 93 to e85.
the guys that i have talked to that use e85 as cheap race fuel with their boosted set ups report haveing to watch their tune from tank to tank.
Old Jun 18, 2008 | 08:30 PM
sdimer350's Avatar
dont waste your time with it. i currantly run it and get 7.8mpg in town (heavy foot) and my truck runs differant on each tank like parish said. im going back to the tuner and running prem. it does smell good tho
Old Jun 18, 2008 | 08:43 PM
MNC5's Avatar
I run E85 and don't have a flex fuel vehicle. I haven't experienced the 30% drop in mileage either. Is it worth it, I think so. Even with a slight dip in mileage its cheaper than running premium fuel.
As far as watching your tune from tank to tank.... E85 can go down to E70 in our area. This would cause you to run a little rich but the trims work pretty well to balance things out.
Old Jun 18, 2008 | 09:36 PM
Lord Aries's Avatar
interesting... the fact i would have to retune to switch back and fourth is enough to not do it. Too much off issue of availiblitly of the e85 at the moment. thanks for quick replys!
Old Jun 19, 2008 | 04:19 PM
stock48's Avatar
9 Second Truck Club
Parish is right, the E85 varies in consistency. If your tune is on the rich side, and you have an AFR gauge you should be able to get away with a 25% mix.
GMCtrk
Jan 27, 2016 06:47 PM
MOBBN
Sep 22, 2015 08:07 PM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
Gmc_sierra
Aug 21, 2015 10:08 AM
