Turbo water cooling...
Old Jun 19, 2008 | 10:45 PM
Bill Reid's Avatar
Default Turbo water cooling...
Is everybody tapping off of the heater core lines? I have an idea or 2 based on previous experience but wanted some feedback...
Thanks
Bill
Old Jun 19, 2008 | 10:48 PM
kbracing96's Avatar
Thanks
Bill
Thats what I've always done
Old Jun 19, 2008 | 10:59 PM
charcold-bowtie's Avatar
yeah, the one that goes down to the Y thingy. And if u cut it just right, you shouldnt have to lenghten it on either side. Look at my install on my started threads if u want an idea.....
Old Jun 19, 2008 | 11:17 PM
Bill Reid's Avatar
I already lengthened my lines because I rerouted them. I guess I'll just tap into them. No problems with boiling coolant in the reservoir?
Bill
Old Jun 19, 2008 | 11:26 PM
no not that i noticed. I have been outta the truck for 3 weeks. ECT will go up when doing a WOT run, i think the highes ive seen mine is around 215. Which isnt that bad since they run around 200 anyway IMO. I will admit it makes me feel a bit better about my engine bay. Just SEEMS like they get way too hot with just oil cooling, although that is a proven combo as well. I used a 45* fitting and a 90*. The 45 helps clear the oil neck, if it isnt removed already.
Old Jun 19, 2008 | 11:50 PM
Bill Reid's Avatar
Cool man...
I didn't have any problems running a dry turbo when I was running a Garrett 60-1. I went with Turbonetics, ala Jose@ForcedInductions, for the T66. I ordered it dry. The first turbo started smoking at WOT (only). Because this is a daily driver I bought a second identical turbo... and sent the other in for warranty. I talked with Turbonetics today and, based on bearing health, they said my EGT's are too high... so they are upgrading to a wet CHRA. So,it just seems a bit odd to me that I had no problems with a 60-1 P-Trim... which should have created greater EGT's... yet I have problems with a T66 with a huge GTK1000 turbine wheel...
Bill
Old Jun 20, 2008 | 12:53 AM
Rick_Vor's Avatar
I installed a Twin Turbo Kit from Rick @ Synergy and just spliced into the 1/4" rubber hose that heats the Throttle body. Seems to work just fine.
Rick
Old Jun 20, 2008 | 06:28 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Cool man...
Bill
Are you sure you are not running a bit leaner with the bigger compressor? Your IATs deserve an eyeball as well imo.
Old Jun 20, 2008 | 08:42 AM
TrickTurbo's Avatar
Truck Sponsor
The water passage way is not real huge by any means. But its enough to help keep the turbo a little cooler, and probably out of the danger zone on heat. We made the transition to the water cooled stuff a few months ago. For nothing more then just another saftey step in turbo life.
If you going to use AN style hose barb fittings, the size we use is -10.
I really like Turbonetics warranty.
Old Jun 20, 2008 | 09:56 AM
Bill Reid's Avatar
When I upgraded the turbo size my tuner checked everything while I drove the truck. I still never get above 11.5 AFR... zero KR. I am running the 42lb injectors with the Magnavolt and the fuel pressure drops a little, till the Magnavolt activates at 3K RPM / 3PSI, then stops on WOT runs. My tuner says my injectors are pretty much done... not over 100% yet. I haven't checked the IAT's since my tuner last looked at them. I could check those as well. But I do remember them being low even after several WOT tuning romps last summer. My little 5.3L still continues to run just fine at 9-10psi. I checked #5 and #7 plugs and they looked great... I didn't bother with the others... but I get no misses or anything like that. The other thing is the smoking is occasional... mostly when the oil temp is below 180F. If I just bring the engine coolant to operating temp but the oil hasn't started heating yet and I hammer it I can dust for mosquito's. If I wait for the oil to get above 180F the smoking is faint to non-existant. I run Mobil1 10W-30... certainly not a heavy weight oil...
Bill
