Dual heat exchangers helping any?
Old Jul 14, 2011 | 06:11 PM
scooter k's Avatar
Default Dual heat exchangers helping any?
You guys running the dual heat exchangers, is it helping any with your IAT's?
Old Jul 14, 2011 | 06:28 PM
Atomic's Avatar
I have a gauge for that
Ill go ahead and say it is very doubtful....the limit of the system is with the intercooler, not the heatexchangers.
Old Jul 14, 2011 | 06:37 PM
1Bear's Avatar
Most people report quicker recovery times rather than actual drops in IAT rates. Just as Atomic said, the system is really limited more so by the internal inter-cooler than the heat-exchanger. That being said, even just having quicker recovery times is not a bad thing; it’s just probably not what you wanted to hear. A larger reservoir may be a good investment as well if you do decide to add an additional heat exchanger.
Old Jul 14, 2011 | 06:39 PM
TIM Z's Avatar
11 sec. Truck Mod
Maybe that phenolic spacer that Trick? had would help more than dual HEX's.
Old Jul 14, 2011 | 06:48 PM
scooter k's Avatar
I have the larger reservoir. I think I could make more power on less boost. The IAT's go through the roof the more boost I try to run. Im running 14-15psi and seeing 160's and sometimes more. 11psi seemed to have reasonable IAT's.
Old Jul 14, 2011 | 07:24 PM
TIM Z's Avatar
11 sec. Truck Mod
Do you have or consdered meth?
Old Jul 14, 2011 | 07:51 PM
scooter k's Avatar
Tried that and currently running E85. Running about the same temps as with meth.
Old Jul 14, 2011 | 08:22 PM
TIM Z's Avatar
11 sec. Truck Mod
Any track times or dyno graphs with different boost levels?
Since you were thinking of lower boost may make more power,
Im wandering why the meth isnt working??
I'd think meth and e85 would help.
Old Jul 14, 2011 | 08:43 PM
scooter k's Avatar
No runs or dyno. Just from driving it.
thunder550
Oct 8, 2015 04:53 PM
vmaxpro
Jul 27, 2015 10:45 PM
Suburban2500
Jul 19, 2015 04:50 PM
4B11T
Jul 13, 2015 03:48 PM
