different sizes
Old Mar 9, 2008 | 03:34 PM
bluecamaroz28's Avatar
Banned
In-line twins setup is used on I6 imports twin turbos. Not sure if anyone tried it on V8's.
Old Mar 9, 2008 | 11:52 PM
Stoichiometric's Avatar
A sequential twin set-up is for 30psi+ boost levels. Your best bet would be to run a single and do your best to keep the heat in the pipe before the turbo. Thick wall tubing, coated, wrapped ect.
Old Mar 10, 2008 | 09:34 AM
t_thall's Avatar
Originally Posted by wastedrubber
i understand the spool times would be different, thats the concept behind it, the smaller turbo would spool first giving early boost, then the bigger turbo would put up the grunt once it spooled. but i don't know much about this sorta thing. what would the problem/s be?
If the smaller turbo spooled up first then i would think the pressure would go out the larger one backwards cause it isn't moving fast enough to hold it in yet
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
Oct 5, 2015 11:18 AM
old motorhead
Sep 29, 2015 08:22 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
