Custom turbo set up build progress
Old Dec 20, 2015 | 10:08 PM
Miller boost's Avatar
Registered User
Originally Posted by Miller boost
Yes 2.5 vband welded on stick manifolds and 2.5 pipe to tuebo
So they do that from heat. Or strain in them. Because once complete there will be no strain on them.
Old Dec 21, 2015 | 12:17 PM
kbracing96's Avatar
If your taking about the flexes, it's from the hot exhaust pre-tubro blowing though them very fast, expanding the SS mesh and then the force of the gas going through them, sucks the mesh out of them. Every one I've ever cut apart after running a while has looked like that or this...
I went away from flexes in my cross over complete a few years ago just because even the "good" ones only last a couple years before they fatigue, crack and start leaking. I use slip joint with SS stretch clamp to seal them, or weld them solid once installed. No problems since.
If you must use a flex, use this type. I use them on my waste gates since they don't see near the flow as the crossover does and they seem to last a while.
http://www.treadstoneperformance.com...Coupler+Bellow
Old Dec 21, 2015 | 10:43 PM
brandon6.0's Avatar
Ive had my flexes do the same thing just after a short 2 day drive. They dont hold up. This is what i done. I pulled the mesh braid out of mine after they blowed apart and rewelded the joint back in. Once u remove the mesh they look just like the better joints with the bellow inside.
Old Dec 22, 2015 | 08:25 AM
DuncR6's Avatar
What motor & manifold is that?
Old Dec 22, 2015 | 12:10 PM
Registered User
4.8. Truck manifolds
droppedchev
Feb 8, 2016 07:08 PM
CCrowell2
Dec 10, 2015 02:06 PM
121
Oct 27, 2015 11:51 AM
Tuckin15s
Sep 23, 2015 09:35 PM
durty
Jun 30, 2010 10:52 PM
