cracked log manifold
Old Jun 2, 2010 | 08:20 PM
  #21
TrickTurbo's Avatar
Truck Sponsor
The silver coatings hold up to scratches but don't go as hot as the black. But the black coatings will scratch off alot easier.
Kyle where were measuring those temps. The final temp of the exhaust gases should be level. Rising temps can be caused by being to lean or to rich. Too much fuel in the pipe will cause alot if heat.
Old Jun 2, 2010 | 09:02 PM
  #22
kbracing96's Avatar
The probe was about 3" pre-turbo so it was an average of the accumulation of all 8 cylinders and my tunes generally run a touch on the conservative side, around 10.9-11.3 AFR.
Old Jun 3, 2010 | 01:49 AM
  #23
xXxSilveradoxXx's Avatar
Originally Posted by kbracing96
I know these truck will run EGTs about 12-1400* in cruising when properly tuned and medium boost setups will run up to about high 1500 to low 1600's in boost. The most I ever saw with mine was when I was compounded with the MP t76 and the blower and it got to 1720's at the track. But these high temps are just the GAS temps when boosting hard, for seconds at a time and not continuous. So I don't think your going to get the piping that hot.
Decisions, decisions. Low 1,600°s don't leave a lot of room up to the 1,700° rating of the extreme sterling coating. Although I understand that there is a difference between the temperatures of the exhaust gas and the outside of the piping. I think I'll end up going with the extreme sterling coating. You haven't led me astray so far!
Pimpinpete
43
Dec 22, 2017 08:13 AM
GMCtrk
Oct 20, 2015 06:17 AM
thewrx
Oct 6, 2015 10:59 AM
murderedSS
Sep 27, 2015 10:16 PM
trevorh1
Sep 27, 2015 08:47 PM
