couple questions
couple questions
4.8 with 70mm on 10-12lbs, can I run the stock maf still, or will it be maxed out already? If i still run it, will the putting in the 2 bar map I have help with tuning, or should I just go SD all together with the 2 bar map.
Also, will I need an oil restricter? I see some need it, and some dont?
Thanks
Thanks
Noah Burns
09-07-2015 05:50 PM
