Compression Ratio ?
Old May 2, 2006 | 04:14 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by TurboBerserker
The rule of thumb on CR should be to run as much as you can and still get your boost in.
Its all about the properly sized turbo
Old May 2, 2006 | 04:32 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Size is everything, you know
Old May 2, 2006 | 04:37 PM
OLD BULL's Avatar
My advice: pick your boost level (even if it means you have to upgrade your turbo down the road) and build your engine for that level.
I ran 10.1:1 with 10-12psi with meth only as the intercooler on stock LQ9 low end parts. I'm not familiar with the precision turbos, but my Garrett GT67 still had plenty at 12psi -- I'm pretty sure you can pull off 15psi no problem.
I built this block for 18psi and targeted 8.6:1 CR with my cam (and meth+intercooler of course).
With that being said I may just go with the 8.5:1 pistons. As addicting as this is I probalbly won't be satisfied with 15psi either. Even with the cr at 8.5:1 it should feel better( not as lazy as) than my bone stock 5.3 being that there is quiet a jump in displacement, head flow (patriotperformance stg3), and cam.
Old May 2, 2006 | 04:43 PM
sliderbkt's Avatar
Old Bull, I went with the 11515's. They are the same dish, but they are made for stock rods. The 11517's use SBC rods.
Old May 2, 2006 | 06:23 PM
OLD BULL's Avatar
Are there any advantages to using the 11515's with stock size rod vs 11517's with SBC rods.
Old May 2, 2006 | 06:44 PM
sliderbkt's Avatar
The 6.125 rods are more available. Other than that I really don't know.
Old May 2, 2006 | 06:45 PM
sliderbkt's Avatar
The wrist pins are bigger on the ls1 rods. But, I don't think I've ever heard of a failed wrist pin.
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
Boyes50
Sep 8, 2015 12:06 PM
