Compression Ratio ?
Old May 2, 2006 | 12:22 PM
OLD BULL's Avatar
Default Compression Ratio ?
Ok I'm slowly piecing together a forged 6l for more boost. My question is what kind of compression ratio should I be shooting for? Please give reasons for you response. BTW I'll be running the same turbo that I'm running now probably just a lot more boost.
Old May 2, 2006 | 02:10 PM
white1's Avatar
HOW mutch boost are you planning?
Old May 2, 2006 | 02:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
no less than 9.5:1 IMHO....any less than that and your truck will feel lazy when it is not in boost.
Old May 2, 2006 | 02:56 PM
OLD BULL's Avatar
As much as this turbo will put out efficiently. Just guessing I think somewhere in the 10-12psi range.
sliderbkt's Avatar
It all depends on how much boost you want to run. I agree with blownchevy depending on boost level. When you get higher, low compression will be more important.
Old May 2, 2006 | 03:10 PM
AintNoHo's Avatar
Depends on what kind of fuel you want to use, how much boost and what size cam. A long duration cam lowers the actual cr. For pump gas with a cooler (10lbs and more supercharged - I don't know turbos) a lot of guys choose 8:1 to prevent detonation. With race gas, meth injection or even pure alcohol and/or spark retard, you can run a higher ratio to get more power. For comparison top fuel dragsters run 45lb boost with 6:1 cr. I'm in the same situation as you. With my new setup (bigger s/c, heads,cam, etc), I'm trying 7.5:1 because I don't want to use any fuel other than pump gas (with N2O). If I don't like it I can always mill the heads.
Old May 2, 2006 | 03:30 PM
AintNoHo's Avatar
Just saw post you added. For 10-12psi I wouldn't go under 8.5:1. I thought you were thinking like 20+psi. You could go higher cr with meth.
Blownchevy, compared to boost 11:1cr feels sluggish.
Old May 2, 2006 | 03:34 PM
OLD BULL's Avatar
Your setup in your signature looks alot like what I'm doing. I haven't picked my cam yet, I'm leaving that to cammotion. What is your cr going to be and what is your part# for those pistons?
The only set that I have found that will get me even below 10:1 is this set
126-11517 Diamond Pistons LS1 Forged Dished Piston set w/ -15.0cc Dish, 4.030" BORE / 3.622" Stroke / 6.125" Rods / 1.310" Comp Height / .927 x 2.950 Wrist Pins Included
With this set the cr will be 8.75:1
Old May 2, 2006 | 03:37 PM
OLD BULL's Avatar
[QUOTE=AintNoHo]Just saw post you added. For 10-12psi I wouldn't go under 8.5:1. I thought you were thinking like 20+psi. You could go higher cr with meth.
I will go 20psi if the turbo can do it, I doubt it will. Basically I will push this turbo to the max and if it's not enough I will just upgrade.
Old May 2, 2006 | 04:04 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
My advice: pick your boost level (even if it means you have to upgrade your turbo down the road) and build your engine for that level.
I ran 10.1:1 with 10-12psi with meth only as the intercooler on stock LQ9 low end parts. I'm not familiar with the precision turbos, but my Garrett GT67 still had plenty at 12psi -- I'm pretty sure you can pull off 15psi no problem.
I built this block for 18psi and targeted 8.6:1 CR with my cam (and meth+intercooler of course).
The rule of thumb on CR should be to run as much as you can and still get your boost in.
