Close call
Old Dec 10, 2006 | 07:41 PM
  #31
DrX's Avatar
DrX
We'll see what happens with this arrangement. New tensioner and pulley, 100mm idler on PS, 90mm lipped idler on DS(pulley that came with the tensioner). Put the original 112" Gates belt on for testing. It's a little tighter then before with more wrap.
I took it for a drive and beat on it for a while. So far so good and performance was improved. No bling like Metcos but so far it's working. I'll drive it like this for a few days then try a different belt.
Old Dec 10, 2006 | 10:03 PM
  #32
XLR8NSS's Avatar
Adkoonerstrator
I'm wondering where the tensioner is at in it's travel range on you guys trucks that are having problems with tensioners and belts.
When I installed my belts for the different pulleys I tried to keep the tensioner in the middle of it's travel range so it wouldn't "bottom out" either way under load or when you let off the throttle abruptly.
Old Dec 15, 2006 | 04:24 PM
  #33
DrX's Avatar
DrX
So far, so good.
Here is an application guide and belt spec lookup for Gates belts:
http://www.gates.com/part_locator/re...esttimeout=500
Can get a little confusing as a K061120 is 112.5", K061115 is 112", K061110 is 111".....etc.
Their parts interchange lookup can come in handy as well for ACDelco and NAPA part numbers:
http://www.gates.com/part_interchang...cation_id=3286
Picked up a NAPA branded belt that looks more like the Gates.
Old Dec 15, 2006 | 04:34 PM
  #34
krambo's Avatar
I agree. Mine is slightly to the "tight" side (NO JOKES GUYS) and have never snapped a tensioner. I have had it to 6500rpms and quickly back-peddled many times and so far so good. I carry a spare under the back seat,...just in case.
Old Dec 18, 2006 | 11:12 PM
  #35
DrX's Avatar
DrX
Mine is a little tighter now with the new pullies. The pulley arm on the tensioner is parallel to the top of the mounting bracket.
Vortec350ss
Jan 12, 2016 10:36 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
gmcyukon
Oct 5, 2015 06:20 AM
94f150
Sep 28, 2015 05:28 PM
