Close call
#21
Originally Posted by krambo
I used red loctite and pinned my crank pulley. Hasen't moved in 1 year and 5K miles.
Bill
#22
About every time I am under the hood I now reach down and try and turn my crank bolt. Not pinned. 3 or 4k miles with the last crank pulley change. Went 10 -15K on the last no problems.
#23
Adkoonerstrator
I typed some stuff up on why the bolt backs out over on Tech a while back. Check this thread.
https://ls1tech.com/forums/showthrea...t=crank+pulley
What it comes down to is by adding extra power and load to the crank pulley the factory interference fit can't keep the pulley from spinning. Once it starts spinning just look at your radix 6.0L as a 500lb-ft breaker bar.
#26
Well the new belt didn't last very long.
It got sliced and blew off in the middle of a WOT blast today. Crank pulley bolt is good and tight. Tensioner looks OK, but I think it should be changed anyway. Something has to be screwed up.
#28
I used a new bolt.
I think that the belt was probably already halfway off again before the last blast when it broke. Then it probably just started slipping and got sliced down the middle because it broke before I let off the throttle. Turned it into 2 belts that wrapped around the fan.
How free-wheeling is the blower when you back off quickly? Or is there a braking action?
Any one have a favourite tensioner? I guess that the Dayco pulley will be needed for any of these:
Tensioner is from a 87-96 Ford F-Truck/E-Van 4.9L or 87-92 Bronco 4.9L
Dayco # 89222, Pulley # 89009
Napa, Gates, ACDelco # 38131
Four Seasons # 45869
Goodyear # 49233
Goodyear # 49233
#30
My guess is still in the idlers. Replace them all along with the tensioner. FWIW I started loosing the AC belt at WOT blasts this summer. Replacing the tensioner fixed that.
