CAI for TVS2300
Old Jan 6, 2011 | 06:10 PM
old motorhead's Avatar
Default CAI for TVS2300
I have an Outlaw CAI now. With air filter in place, I'm seeing 9.5 to 10 psi. When removed, I see 11.5+psi. I knew something wasn't right when I went from 3.4 to 3.1" pulley and only picked up 1.5 to 2psi. Need to get the Outlaw replaced, but want to still be sucking cold air. Does anyone have one to recommend that's been proven at high HP levels? I thought the lack of boost was due to belt slip, but that doesn't seem to be the case. With the filter in place or removed, the boost gets to max psi quick and holds to redline. TIA..
Old Jan 6, 2011 | 06:12 PM
RibeiroBJJ's Avatar
Praise The Lowered
Airaid or some have said the Spectre flows good.....You could always make a custom setup
Old Jan 6, 2011 | 06:44 PM
scooter k's Avatar
Are you running it through stock MAF and tube that came from Magnacharger?
Old Jan 6, 2011 | 06:51 PM
03sierraslt's Avatar
I have a Airaid box on mine with the magnacharger tube and no MAF, one of my things on my list for the winter is coming up with something as far as 4" tubing straight from airbox to TB.
Old Jan 6, 2011 | 07:12 PM
No MAF. I have a 45 degree 4" exhaust fitting going from CAI to t'body. It has a smooth gradual bend. No restriction there.
Old Jan 6, 2011 | 07:20 PM
Atomic's Avatar
I have a gauge for that
Are you using the jackshaft version or the front drive version?
Old Jan 6, 2011 | 07:28 PM
He is using the front drive.
Old Jan 6, 2011 | 07:54 PM
Atomic's Avatar
This is the homemade intake I did for my tvs1900, should be the same as yours
Old Jan 6, 2011 | 08:04 PM
terravast4's Avatar
I did the same....4" into a volant box.........
Old Jan 6, 2011 | 08:28 PM
What's in the box? I'm 4" from the t'body to the box/filter. The Outlaw filter looks fairly big, but obviously isn't doing the job.
