brace for procharger
#53
LOL
#54
Fastest D1 Procharged Truck
i actually thought about doing it that way but was afraid of the engine moving around would cause issues but if you use heim joints like i did i think you'll be good
i still might do it that way if it works out for you
#55
My idea behind was to make everything adjustable. In case I did run into a problem, I would be able to fine tune it. Also I liked the idea of distributing the force over 4 bolts on the supercharger.
#57
Works like a charm! It's F***ing stout. I made a brace from the upper radiator support to the lower support. I used 1" square stock and welded square 3/8" nuts inside the tube so it could be attached. The adjustment rod is from summit. It's a March adjustment rod. Part # MCH-RA8-000. Let me know what you guys think.
#60
It looks like urs, because I picked ur brain about awhile back blown06!
Next step is align the pulleys with the gates tool. Then on to the Jakes lvl5 with t-brake and two step!
I also feel it's important for people to check the accessories bracket for cracks. I had to weld mine up because it cracked from the procharger bracket flexing.
