BOV not working?
Alright, that deffinetally sounds like its a good source. Ill try to hook it up there again tonight, Also what size line are you running? Is it just rubber hose or air line or metal line ect..?
Some times those BOV get stuck from sitting so long. Might pull it off the pipe and manually push it open. A little silicone spray on it will help too. The spring that comes in them is really stiff. I usually cut them down, but don't remember if I did on that one or not. You will still get some compressor surge, that is normal unless you put a really light spring in it. It uses the same springs as a tial if you want to buy a lighter one, but you can also just try to find a light one at you local hardware store.
I have a tial it had the 12psi spring. I needed about a 6-7 So I started cutting off coils 1/2 a coil at a time. Took 3-1/2 coils before I got it right. You have to use a some kind of grinder or dremel. I couldn't cut mine with anything else. Start with half a coil at a time. Take it for a drive, if it doesnt work cut another 1/2 coil off...
Yes I am connected on the top port, my BOV actually looks exactley like yourse. What kind is yourse? Did you mean what port am i connected to on the intake manifold? If so I actually just took the vacuum line off that goes to the fuel pressure regulator, just to make sure it works before i drill into my intake. There is plenty of vacuum coming of of that at idle.
Is there a certain size line i should use? mine is pretty small right now, what size are you running?
I have a boost distribution block running off that tab. I am running bov, wg, bc, and bg off this one port with no problems at all. Sounds like something is wrong with your bov. Nick
