bov
Old Aug 11, 2011 | 05:17 PM
cwalker2006's Avatar
Default bov
Can anyone with some knowlege about bovs message me plz.
Old Aug 11, 2011 | 05:48 PM
ok i have a bov from rick from trick performance....they guys that rebuilt my motor dont wanna put it on because they say its messed up. im not sure how they work but if im not mistaken arent they supposed to only open up when you let off the throttle after boost?? they are saying thats how i blew my motor when i clarly told them i hooked up the wg wrong. they said its supposed to be set the same as the wg so if it sees to much boost it will open even during boost.
Old Aug 11, 2011 | 08:33 PM
black04's Avatar
It opens up when you let off the throttle after boosting.
Old Aug 11, 2011 | 08:35 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
is it to late to rethink them building your motor
Old Aug 11, 2011 | 08:38 PM
blue0453's Avatar
These guys are clearly idiots, and apparently dont know much about boosted setups. I would reconsider letting them work on my truck.
Old Aug 11, 2011 | 10:06 PM
TrickTurbo's Avatar
Truck Sponsor
Hmm didn't We talk early about this?
Most bov have one port. This port connects to a vacuum sorce after the throttle body.
The bov will open when there's a large enough pressure differential vaccum/boost to off set spring psi.
Normally you want to have enough spring psi to remain closed at max vacuum no boost.
The valve will open when your boosting and then closed throttle.
At this point. Vaccum is pulling on bov, boost pushing the bov valve.
This is a large offset then spring psi. Valve opens.
I believe your engine builder is thinking wrong or maybe a bypass valve. Who knows. Like I told you today on the phone,
If you want send the valve back I will check it out.
Sucks is they took it apart already and not sure if they put it back together correctly.
Old Aug 11, 2011 | 10:17 PM
Coban's Avatar
Yea, the guys that are building your motor must not know their *** from a hole in the ground.
Old Aug 12, 2011 | 12:13 AM
Tjats exactly what I kept telling him... I dunno. Hope my motor is good lol. I told him it was good and I would do it myself. Damn they justvwant me to spend more mobey
Old Aug 12, 2011 | 12:15 AM
Rick its fine. They just dont know what they are talking about and im going there tomorrow.
JordanH
Feb 19, 2019 07:46 AM
03chevytruck
Nov 7, 2016 04:43 PM
Tuckin15s
Sep 23, 2015 09:35 PM
97_ek
Sep 23, 2015 09:16 PM
6.0l RST
Jul 7, 2015 02:22 PM
