boost creep
#41
He did use different springs... At first 7lb and then put 3lb springs in and had the exact same results, and this was using just spring pressure to run WG's... No controller. With both spring variations he would see boost climb to 7-8.9lbs.
#42
I knew I'd get alittle boost creep but with the 3psi spring I was hoping to stay at about 5 not the 7 it's hitting haha I'll see what turbosmart says maybe run 2 60mm gates and hood vent the bitcjes. Or fender. And I ran all new lines each time I have a few hundred feet of the push lock line.
#44
#45
#46
