Boost Creep
Old Apr 13, 2008 | 09:00 PM
charcold-bowtie's Avatar
Now you should buy some of KB hot parts to repay him, he saved u from. Definatly need to get that AFR down
Old Apr 13, 2008 | 09:18 PM
SpoolinChevy's Avatar
If i wasn't planning on the motor swap, i would. Once the 6.0 is in, it will still be using the same tune since i'm keeping the same computer correct? So will it be doing the same thing? I guess i don't really need to know considering im not going to drive it much untuned, i was just curious.
Old Apr 13, 2008 | 09:19 PM
Dragframe's Avatar
9 Second Club
Originally Posted by Maroon20's.
The controller was backwards. I didn't get all the way in it, but the controller is definitely working now, but the wide band still stays in between 14-15.
Yeah... i wouldn't get into boost at all with that afr unless you really really want to put a new motor in soon
Old Apr 13, 2008 | 09:25 PM
Well i didn't want to blow it up, so i could recoup some coin. The 6.0 is sitting in the garage.
Old Apr 14, 2008 | 08:31 AM
TrickTurbo's Avatar
Truck Sponsor
Still way to lean for a boosted application. did you get to compare the dyno a/f to yours to make sure its close?
Old Apr 14, 2008 | 01:32 PM
That dyno was done before i had the wideband installed. So i didn't.
Old Apr 14, 2008 | 04:27 PM
custom 68's Avatar
well I guess I am confused and I dont know much about turbos (yet) but you AFR looks right in the above chart. If the tune didnt change why would they be different? or is this after a tune change?
Old Apr 14, 2008 | 06:19 PM
I dont tune myself, so i did nothing to alter the tune. I got the tune in August of 07, and just installed my wideband last weekend. So either it has changed that much, or my wb isnt working correctly.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
