blower help
Old Jul 6, 2012 | 09:41 PM
  #21
03sierraslt's Avatar
Where did you get the blower from? What color are the injectors?
Old Jul 6, 2012 | 09:51 PM
  #22
Here are some values to take a look at, mind you I just came up with them. I am not responsible for anything that happens. I dont know yet what injectors you have and if that info is correct. I do know that it was not going into PE soon enough though.
Old Jul 6, 2012 | 10:11 PM
  #23
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by jeforton
the injectors have this number: 17113736
I came up with 96lbs depending on the 4 digit code and the brand. Siemens and Delphi both used this part number. Siemens also had a 55 Lbs version using this part number. Delphi only reference as a 96Lbs
See if there is a 4 digit code some were else on them. A brand might help narrow it down as well.
Old Jul 6, 2012 | 10:43 PM
  #24
jeforton's Avatar
i ordered the kit through BlownChevy. they're black, 4 digit code is either R80B or R808
Old Jul 7, 2012 | 05:45 AM
  #25
That's simple then, send Brian a message or get ahold of him to find out. For some reason I thought they came with 48's or something, I got mine without injectors.
Old Jul 11, 2012 | 11:15 AM
  #26
jeforton's Avatar
he finally got back to me. the injectors are 42# delphi. and my wideband that i "overnighted" on friday is out for delivery. hopefully i can get this **** all sorted out today
Old Jul 11, 2012 | 11:27 AM
  #27
42lb at what pressure?
Old Jul 12, 2012 | 02:30 PM
  #28
jeforton's Avatar
well, BlownChevy hasn't been feeling very talkative the last week.
got the wideband up, runs around 15-16 afr at idle and light throttle, i'm commanding (tried anywhere from 12-9:1, all acts the same) 9.x:1 afr at WOT, the wideband goes off the scale at 18:1 at WOT. at around 50-60% throttle it'll read around 12.5-13:1. can't say if its fuel pressure, my gauge works, but the fitting isn't the right size, it leaks. so maybe i don't have enough fuel pressure to run WOT? it pulls all kinds of knock retard out, but i'm sure it doesn't help that my IATs are 200*. i need to drive 1300 miles tomorrow, wft am i doing wrong?
File Type: cfg
File Type: hpl
File Type: hpt
Old Jul 12, 2012 | 02:33 PM
  #29
So you have fuel leaking at the fitting?
Old Jul 12, 2012 | 02:36 PM
  #30
No way your IAT's should be that hot, is your intercooler pump running? Who installed this blower?
