blower help
Old Jul 12, 2012 | 05:57 PM
  #41
jeforton's Avatar
if how the thing runs is any indication i'd say you're being polite.
Old Jul 12, 2012 | 06:24 PM
  #42
03sierraslt's Avatar
Well if your injectors are 42lb at 43.5psi then your IFR table needs to be 48.5 since gm uses 58psi fuel pressure. This still doesnt explain why you are lean, almost seems like you have a hell of a vacuum leak. Post up some pictures etc. Something is going on here. Your fuel trims are maxed, it needs fuel. Next time you do a log you need to log MAF HZ. If you have a stock tune, post it up. Need to see what you changed.
Old Jul 12, 2012 | 06:26 PM
  #43
Another thing that doesnt make sense is that your injector duty cycle is 85% at 4800 rpm and you are that LEAN.... How much boost are you running again?
This thing is screaming vacuum leak. To me anyway.
Old Jul 12, 2012 | 08:58 PM
  #44
jeforton's Avatar
i've run a tube all the way around the engine twice listening for leaks. i've sprayed it down multiple times with ether, the intake, blower manifold, around the heads. no reaction what so ever. i've taken it to two mechanics and they both said no vacuum leak. both said it looks to be mechanically sound.
one thing that sticks out to me, what would happen if the fuel pressure regulator saw boost instead of vacuum? on the stock manifold it only had access to vacuum. as per the enclosed installation manual from magnuson, it has the FPR plugged into the only vacuum/boost port on the blower. would that do anything weird?
File Type: hpt
Old Jul 12, 2012 | 09:00 PM
  #45
jeforton's Avatar
the stock 3.6" pulley on a tvs 2300 should be around 6psi. the gauge has never shown much more than 5, but i've never been WOT much over 5000 rpm, red line is 6600.
Old Jul 12, 2012 | 09:23 PM
  #46
You need to see what your fuel pressure is doing.
Old Jul 12, 2012 | 09:41 PM
  #47
ak2007r6's Avatar
Just speaking from experience be super careful till you get that thing sorted out. Boost plus being lean is an equation for a very very bad day.
Hope you get it sorted out.
Old Jul 12, 2012 | 09:54 PM
  #48
jeforton's Avatar
tried to log the MAF HZ, computer is reading no MAF. the log i have from earlier today has a MAF working. i unplugged the MAF sensor and the truck kept running. as its been stated, i'm no expert, but that should have killed it instantly right?
Old Jul 13, 2012 | 04:28 AM
  #49
No, when you unplug it then it defaults to speed density. Only problem with it defaulting is then you CANNOT Go into boost. Are you sure your MAF is working? Did you have to extend the wires? That may explain why its not richening up, although the Injector duty cycle seems to say it is trying. Need to know what fuel pressure is doing. Period.
Old Jul 14, 2012 | 01:17 AM
  #50
jeforton's Avatar
as per the instructions i cut and extended 2 wires from the MAF plug in to a sensor on the blower. every log i have prior to this shows a working MAF. i'd swap it out to check, but i now sit 1300 miles from the truck. any hands on trouble shooting will have to wait till october or december. maybe longer
