Blower air temps?
Old Jan 17, 2020 | 06:54 PM
  #21
03sierraslt's Avatar
Originally Posted by TrickTurbo
Wonder why y’all see 15-20 over ambient.
The Lightning see’s much higher air temps.
So we built them a large ic. to help.
Anyone here pushing 20+?
the lightning has a horribly inefficient compressor compared to a TVS.
Old Jan 17, 2020 | 07:11 PM
  #22
TrickTurbo's Avatar
Truck Sponsor
Whipple 3.4, 2.9, or the KB. KB always seem higher air temps then the whipple..
Think they are also working on the 4.0L for it.
Old Jan 18, 2020 | 08:54 PM
  #23
smokinlmm's Avatar
where is the air temp sensor those temps aren’t bad at 14on a blower
Where magnuson has you splice it into the harness, stock Maggie location.
Old Jan 19, 2020 | 07:28 PM
  #24
dantheman1540's Avatar
What mixture of coolant do you guys run for the blowers? Dexcool? Hose water? Water Wetter?
Old Jan 19, 2020 | 08:59 PM
  #25
I used to run 25% coolant, 75% distilled water. Mine wasn’t driven in freezing temps though and garage never gets below 50 deg.
Old Jan 19, 2020 | 09:02 PM
  #26
arthursc2's Avatar
Dex 50/50, but my Tahoe sees -17 on some trips 😞
Straight water is the best heat exchange media, so if you don't freeze, and the blower doesn't hit boiling temps, straight water for the best performance
Old Jan 19, 2020 | 09:35 PM
  #27
I ran Dexcool for awhile and then swapped to Distilled water and water wetter because it's cool to say and should provide some anti corrosive properties.
Never really noticed a cooling difference going to straight water, mostly did it because it's cheaper and easier to clean up.
Old Jan 20, 2020 | 07:51 AM
  #28
terravast4's Avatar
I use 50/50 with water wetter
Old Jan 20, 2020 | 10:47 AM
  #29
ZO6Ted's Avatar
I guess mine is 50/50 it's that orange stuff whatever the best brand was. Maybe I need to drain some and add distilled back in the mix huh?
Old Jan 20, 2020 | 11:48 AM
  #30
arthursc2's Avatar
more water = more better, unless freezing or boiling can be a thing where you live
https://www.topgear.com.ph/columns/m...r-a57-20180515
