Blower air temps?
Old Jan 21, 2020 | 03:49 PM
  #41
Atomic's Avatar
I have a gauge for that
Originally Posted by TrickTurbo
Looks like
you could raise your blower at least an inch.
Is there an intercooler(s) between the turbos and the blower?
No, the back of the blower is nearly touching the firewall since I already have a 1/2" spacer for my nitrous/meth spray bars.
Yes, there are A2W intercoolers right below the turbos. Heat exchanger is in front of the radiator and water tanks is on the fender.
Old Jan 22, 2020 | 11:54 AM
  #42
1redta's Avatar
Trick Flow, are you sure about the most flow being better? Think of an engine without a thermostat
Old Jan 22, 2020 | 12:07 PM
  #43
TrickTurbo's Avatar
Truck Sponsor
Trick flow???
Yes, absolutely. With an engine you are using air to remove the heat from the water.
With an inter cooler you are using water to remove the heat from the air.
You only achieve the maximum heat transfer with the largest temp drop.
Largest temp drop only happens with more water flow all other things staying the same.
Old Jan 22, 2020 | 08:46 PM
  #44
1redta's Avatar
sorry, Trick Turbo
Old Jan 23, 2020 | 02:59 PM
  #45
TrickTurbo's Avatar
Truck Sponsor
sorry, Trick Turbo
mall good. I get that a lot. maybe they should buy me out.
Old Jan 26, 2020 | 05:39 PM
  #46
xxch0dyxx's Avatar
Im in Texas... and have a blower truck i would let you experiment on.... You know, to benefit the community and all...
Old Jan 26, 2020 | 08:22 PM
  #47
terravast4's Avatar
i second this. I have a TVS 2300 with a 1” spacer. I would buy a larger intercooler. Maybe a small group buy ??
Old Jan 26, 2020 | 10:19 PM
  #48
dantheman1540's Avatar
I'm in
Old Jan 28, 2020 | 08:04 AM
  #49
TrickTurbo's Avatar
Truck Sponsor
what blower? What temps are you seeing?
where is Texas?
Old Jan 28, 2020 | 08:06 AM
  #50
TrickTurbo's Avatar
Truck Sponsor
way to early for group buy. Need more info prior to even getting to the costs.
Many seem to not have temp issues?
Guessing they don’t push the blowers hard, or their system is dialed in maybe?
