Bigger Radix heat exchanger??????
Originally Posted by TurboGibbs
Since mine weighs 6k anyway, who cares about alittle extra weight.
From what I understand the intercooler in the blower is the limiting factor, not the heat exchanger. Most people with larger heat exchangers didnt see much of a change in IAT. I know on mine heat soak is an iat killer.
With the intercooler in the manifold you will suffer some adiabatic efficiency issues. The manifold intercooler will reach a temp and hold it until the vehicle cools down. With a thicker (deeper) intercooler the adiabatic will be less, but still apparent. The bigger heat exchanger will help, but only a small amount.
This is what i did, I will have the install done on Saturday. I will have some numbers to compare then.
https://www.performancetrucks.net/fo...d.php?t=385387
