Is a bigger blower a better blower?
Old Apr 21, 2007 | 02:03 AM
  #31
Spoolin's Avatar
GFYS and STFU
Originally Posted by James B.
Spoolin - Positive displacement and twin screw compressors spin with very little mechanical losses to friction. Under vacuum there's almost no parasitic draw on these types of compressors. Air moving against a surface creates friction. The faster that air moves the more friction and heat are created. Overcoming this friction transforms mechanical energy into heat. The heat is transferred to the air. This is why efficiency falls off at higher RPM - more energy becomes heat. In a roots or screw supercharger you have two counter rotating rotors. In a roots blower they spin the same speed, in a twin screw compressor the second rotor is geared up to spin faster. The mass of the rotors in both designs creates a lot of inertial load on the engine. In first gear, for example, when the engine is revving up fast, inertia of those rotors has to be overcome with input torque. It takes a lot of energy to accellerate a few pounds of aluminum from 1500 RPM to 16,000 RPM! Then, when the transmission shifts, you have all the inertial energy trying to overspin the crank pulley since the engine loses RPM much faster than the blower. That can cause the belt to jump off the pullies and/or even break the belt tensioner. The larger displacement compressors reduce inertial forces even though the rotors are more massive. There's a lot less accelleration of those rotors due to the slower rotation to achieve the same boost.
The belt around the 2.625" pulley on my W140AX is not slipping, amazingly. If I were running the larger W200AX compressor at the same boost levels I am getting from the 140, the puley would be much larger giving the belt more grip and more leverage on turning the rotors. The 6-rib serpentine system would work fine with that. My biggest problem is with engine decelleration adn the compressor overspinning the crank. It shifts all the belt slack to the driver side of the crank pulley and pulls the tension so tight it maxes out. This happens during shifts and after burnouts when the tires grab. (Any time the engine RPM rapidly decreases)
Ok, so bear with my because I don't know much about S/C since I've never owned one and only driven one truck that had one. What would the effect be on the engine if a pulley were made to spin only one way (like a ratchet effect) so when the engine/belt tries to slow down the blower the pully would free spin sorta like a bike chain and pedals when you stop pedaling therefore not loading the engine? Probably have an overboosting effect for a split second but the blower should slow itself down without bogging down the engine. There's obviously alot I'm overlooking but that's why I don't design blowers.
Old Apr 21, 2007 | 01:07 PM
  #32
James B.'s Avatar
Funny you mention this, I've thought about doing something very similar. One of these days I am going to try to fabricate a crank pulley that has a roller clutch or a sprag from an automatic transmission in it. It will serve as a mechanical diode.
I think it would work well.
Old Apr 21, 2007 | 01:20 PM
  #33
tracy.reich's Avatar
On the newer military HMMWVs the generator has a pulley like what you guys are talking about, the generators are huge on them and have more rotational mass than even my 200-ax. These pullies are 8 rib, I havent seen one taken apart yet so I'm not sure exactly how they work but I would imagine that it has a roller sprag much like an auto tranny.
Old Apr 21, 2007 | 01:41 PM
  #34
Spoolin's Avatar
GFYS and STFU
I haven't thought it out all the way but it made sense when I was thinking about it. Sorta like I was telling Richard@WCCH someone should design and build a variable a/r housing for turbo's. That would prove to be a little more complex but the technology's out there (certain thrust vectoring applications). It just hasn't been integrated into other markets because it's still so new and $$.
I'd be excited to learn what you find if you make one.
Old Apr 21, 2007 | 11:15 PM
  #35
jimbob's Avatar
11 Second Club
Originally Posted by Stoichiometric
The bigger superchargers definetly take more engine power to turn, you get into 8 rib, 10 rib then cogged belts to drive them. The payoff from the larger compressors must be worth the increased power they consume, they make more HP.
I was a little curious what it would take to make 1K RWHP with a supercharger. There was a thread on the Corvetteforum that had a 408 with the KB 2.8 making 8xxRWHP. That was on ~21lbs of boost (unsure of pulley size), manual trans I think. It seemed that the set-up was pretty well maxed out, so I would assume a bigger compressor is needed to make more power. I can't wait to see some results from the trucks around this site!
James, do you have any belt slip or feel the need to upgrade the drive? If you were to run the 200ci compressor, what belt would you use?
That was 16.5 PSI to make 800 rwhp with the "2.8H" (H for high pressure). He's going to 20+psi to see if he can get 900+RWHP....The Guy from EAD said he saw a dyno number of 1000RWHP from a maxed out 2.8! I guess if the combo was right and used more cubes and less boost and a **** ton of Meth then it could be done. "800" at 16PSI is pretty damn good. Looks like a 402 Cube like his is going to need to spin 18,000rpms to make that 16PSI. With the 20+PSI he's talking about (upper and lower pulley will be 2.5 and 8 inch) it looks like 22000 rpms to make 20+PSI on that engine combo, we'll see if the blower can stand that, and for how long.
Old Apr 22, 2007 | 10:31 AM
  #36
Stoichiometric's Avatar
Thanks for the correction on the pressure. That means there is more left in the KB since it is the high pressure model. I'll keep a look out for the new numbers on 20psi.
Old Apr 22, 2007 | 03:22 PM
  #37
jimbob's Avatar
11 Second Club
No biggie...
I just want to see someone get to 1K RWHP....With "American's" combo 900 would be very cool...
calsdad
Jun 14, 2023 11:07 PM
$A_Money$81
Mar 27, 2023 10:25 AM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 22, 2015 02:50 PM
Alco
Sep 4, 2015 04:08 PM
