Belt Chirp when WOT - TVS1900
Old Sep 13, 2013 | 08:19 AM
bgray's Avatar
TOTM: June 2007
Default Belt Chirp when WOT - TVS1900
Hey guys
First off this is my first S/C truck, so maybe this is normal, maybe its not. My truck is pretty much stock with a tvs 1900 with a smaller pulley making 9 psi.
If i hammer on it off the line persay at WOT, then let off the gas at like 5000rpm the belt will make like a chirp or squeal, sounds like its slipping. Also UNDER WOT, when it gets really high in the rpm you can here what SOUNDS like belt making some sort of noise.....but not like the normal wet belt/worn out slipping Serpentine belt noise.
Inspect the belt, and I see no marks on it, or signs of slipping.
Yes tensioner is fully depressed and tightened
Is this all regular noises?
any insight?
Old Sep 13, 2013 | 08:28 AM
supercharged680's Avatar
i know exactly what your talking about its frustrating, i fixed mine after i did a cog rear, i assume u have the front drive not the jackshaft.
Old Sep 13, 2013 | 09:06 AM
03sierraslt's Avatar
I used to get belt noise when I had a 6 rib also.
Old Sep 13, 2013 | 12:44 PM
swift700's Avatar
I get belt chirping when I let off from high rpm's.
Aside from the noise, I don't mind it, as I see it as some relief for one or more components in the serpentine system under a rapid speed change.
Old Sep 13, 2013 | 01:45 PM
bgray's Avatar
TOTM: June 2007
Ya its a tvs1900, so no jack shaft
IT doesnt feel like it loosing power or boost on the gauge, but didnt know if it was alarming
thanks chaps
Old Sep 13, 2013 | 01:53 PM
Does anyone make a nice 8 rip setup complete kit for these guys?
They make 1900's that are jackshaft, you have a front inlet / Front drive.
Old Sep 14, 2013 | 11:50 PM
therock's Avatar
Just brainstorming some possibilities, Your smaller pulley may have let off on your tensioner's range of motion and changed its spring rate.
You can look for a larger idler(s)or a little shorter belt, to put the tensioner at the point it was with the larger pulley.
In putting a smaller pulley on you in a way loosened the belt. To what degree depends on how much smaller a pulley and/or if your tensioner's spring rate changed much.
Other than a different belt you may want to try a Gates tensioner if you are not already running one. I swapped ou the one that came with my Maggie for the Gates and could tell it is some what of a bear in comparison. The Supplied tensioner at center of travel was 30-32 lbs, the gates is 40-42 lbs.
Old Sep 15, 2013 | 07:20 AM
swift700's Avatar
I have the 8-rib setup, the HD tensioner, and a shorter belt and it still slips at letoff.
Old Sep 15, 2013 | 09:10 AM
bgray's Avatar
TOTM: June 2007
Ya i think its the nature of the beast. When i pullied down, I did switch to a slightly smaller belt even tho they say you don't have too. My tensioner on the TVS is mechanical and not spring loaded, unless you are referring to the stock tensioner it uses also
Old Sep 15, 2013 | 09:31 AM
leftcoast32's Avatar
FormerVendor
You will get a chirp on gear change from the Alt pulley. The Alt can not change RPM as fast as the rest of the driven components. This doesn't hurt anything.
