Belt Chirp when WOT - TVS1900
Old Sep 15, 2013 | 09:39 AM
03sierraslt's Avatar
Originally Posted by bgray
Ya i think its the nature of the beast. When i pullied down, I did switch to a slightly smaller belt even tho they say you don't have too. My tensioner on the TVS is mechanical and not spring loaded, unless you are referring to the stock tensioner it uses also
The tensioner location is the same, the one you are refering to is a adjustable idler.
Old Sep 15, 2013 | 10:28 AM
therock's Avatar
Heh! She is either protesting or Sighing in relief.
On mine I had belt dust on the snout till I went to the Gates tensioner, and a new Gates belt. I run 3.4 & 3.5 pulleys.
Old Sep 15, 2013 | 02:15 PM
bgray's Avatar
TOTM: June 2007
Have a part # for the tensioner?
Might as well go with a better unit regardless if its slipping or not
Old Sep 15, 2013 | 02:27 PM
therock's Avatar
I did a post on it back in 2009, see it HERE. The prices are different now and O'Reilly's auto parts are good about carrying Gates stuff and can search them by Gates P/N's. Here is GA anyways.
Old Oct 3, 2013 | 12:13 AM
ls6musclehead's Avatar
I'm with Leftcoast32. My naturally asperated 6.0 did this and was driving me nuts. We have a starter/ charging system rebuilder next door so I talked to him about the alt clutch pulley. He installed one for me on my alternator and the belt chirp is gone at WOT trans shifts. Honsetly I would try it the pulley was only 40 bucks and the builder installed it for me in like 5 minutes for the price of the pulley. Gm has used them on Corvettes for years and GTP Grand Prix's also.
Old Oct 3, 2013 | 12:47 AM
therock's Avatar
Interesting. Do you have a part number?
Old Oct 3, 2013 | 08:09 AM
bgray's Avatar
TOTM: June 2007
Ya part # your referring too?
Old Oct 4, 2013 | 06:00 PM
bgray's Avatar
TOTM: June 2007
I ended up popping that tensioner on, and it improved the noise a little bit. But as itwas stated, its not really belt slip, but more of a bit of belt noise from wot to nothing.
Had to trim about 2mm worth of metal off a 1 inch section of the tensioner for it to fit perfectly, but besides that it works great
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
