Behold the 383 shortblock
Old Jun 14, 2011 | 09:49 PM
  #121
yurs78's Avatar
Can't wait to see the numbers. I've really wanted to see what a 383 w/ the 4" stroke puts down for torque; especially in the lower rpms. Best part is yet to come. Thanks for sharing!!!
Old Jun 14, 2011 | 10:44 PM
  #122
swift700's Avatar
I got it running. It's running rich but no leaks. I have no driveshafts yet but soon. I ran it up to temp and I'm really happy so far. Great oil pressure. It'll be on the road after I get the tune figured out and the driveshafts in. Life is good.
Old Jun 15, 2011 | 01:51 AM
  #123
TXBlownTBSS's Avatar
Originally Posted by swift700
I finally got my valve seats machined and got a lot done today, even with a torn ligament in my hand. The heads went on easy even with the studs in place. There was lots and room and torquing was a snap. The blower is on but I'll need to shim some pulleys before the belt goes on. I should get quite a bit done tomorrow.
Haven't seen a comment in a while, is anyone actually following this?
Looks awesome!!! Ive been watching sir. I cant wait to see this beast on the road!!
Old Jun 15, 2011 | 08:59 AM
  #124
JFOLM's Avatar
Glad to hear it is running!
Old Jun 15, 2011 | 11:36 AM
  #125
swift700's Avatar
I can't seem to get it to run very good. I've put in the tables for the MAF and injectors and am running the 1-bar MAP. It shows 7 degrees of knock retard for some reason. I'll keep plugging away.
Old Jun 15, 2011 | 07:51 PM
  #126
Doobie's Avatar
I've been following from the start. Sure is gonna be a fast stump puller.
Old Jun 17, 2011 | 08:09 PM
  #127
swift700's Avatar
I got my driveshafts in and installed. I fired it up and went for a 10 mile drive. The transmission feels great, the lockup is awesome. It shifts just right as far as I can tell. I'll need to get used to driving with a stall but so far I like it. There are no leaks anywhere but I have a couple little problems. First is the idle settings which have it idling pretty poorly. Once I'm going it seems pretty nice and feels like a beast already. The wideband is showing an acceptable 14.8 or so in cruise and down to 11 or so when I put the pedal down. The other problem is some vibration above 60mph which feels like driveshaft vibration. I'm going to flip the driveshaft 180 degrees and see if that helps. No leaks at all so far.
Old Jun 17, 2011 | 11:08 PM
  #128
Go5.3tt06's Avatar
You sure it was lm7 5.3 change to 383? Did it cause overheat since of cylinder wall become to thin since of bored to 383? where crank come from 5.3 or 6.0?
Old Jun 18, 2011 | 12:13 AM
  #129
swift700's Avatar
This is an LM7 as stated at the beginning of the thread. It's been running a steady 185 degrees so far. I haven't heard of anyone having overheating problems with their 383's before. We'll see how it goes with 90+ degrees temps.
The crank is a Manley forged 4" stroker crank.
With my 5.3 I really had to stomp on it to smoke the tires. Now it's like half pedal or so. I'm breaking it in right now but when that's done it's going to be a lot of fun.
Old Jun 18, 2011 | 09:51 AM
  #130
JFOLM's Avatar
Keep up the good work!
