beautiful twins
Old May 8, 2006 | 07:39 PM
  #81
parish8's Avatar
single digit dreamer
Originally Posted by XLR8NSS
Lookin good Jim. What did you use to fishmouth those primary stub pipes?
http://www.neufamily.org/images/turboworkgallery/
Old May 8, 2006 | 07:42 PM
  #82
parish8's Avatar
Originally Posted by moregrip
what are your suspension plans for this year?
btw: I like your KISS approach to this one, good way to start
none...... for now anyways. i want to try the mt drag radials but probably not till after drag week. might as well wear out the nittos first.
way down the line like maybe next year i MIGHT step up to a good rear and 4 link.
Old May 8, 2006 | 08:32 PM
  #83
duwem's Avatar
Originally Posted by mjhoward
On the topic of the auto-darkening helment, I have a Harbor Freight special (Western Industrial I think) that I have been using for several years and it works great. $49 if i'm not mistken. It is one of the cheap products that is actually good.
no offense, buy my eyesight is worth more then 50 bucks....I wouldnt get anything unless it was a name brand like miller or lincoln, just like anything, price and name matters, just like my eye sight does
Jim, put a 4 link in that thing already with a ton of adjustablility and good shocks....
Old May 8, 2006 | 08:50 PM
  #84
parish8's Avatar
i am all about staying on a budget. i think my shield cost $80. it seems to work good. it is a little too dark for me when it isn't shaded but thats probably how they all are.
i got one header done except for the waste gate, woohoo!!!
Old May 8, 2006 | 09:28 PM
  #85
03lowriderss's Avatar
start producing those headers, and put them for sale here on pt.net they look damn good,
Old May 8, 2006 | 10:20 PM
  #86
parish8's Avatar
if everything works out and this less than perfect design proves able to make some big numbers i might be willing to make a set or two of the headers and down pipes. i dont know how many people would be interested in such a set up. even with the headers and down pipes done there is a considerable amount of work to be done.
the main loom that goes from the fuse box to the intake will probably need relocated.
the battery will be relocated but that may not have to be done.
some brake lines will need to be relocated.
ac probably wont work.
Old May 8, 2006 | 10:38 PM
  #87
ibtravis's Avatar
nice setup.
Old May 8, 2006 | 11:26 PM
  #88
James B.'s Avatar
I bet those work very well. The curvature and angle of the port primaries entering the log will set up a vortex inside the log. I think the spiralling of the exhaust will smooth out pulsation some and flow well in the process.
Old May 8, 2006 | 11:47 PM
  #89
PappyDan's Avatar
Tribe Shaman
jim you cut kind of close on that last spark plug.
i see you can get it in and out.
Old May 9, 2006 | 12:04 AM
  #90
duwem's Avatar
you an engineer or just using big words, I'm in fluid dynamics and that doesnt seem to jive sir....the runners arent running tangental to the log wall, so no spiral vortex tornado huricane effect will be introduced, the turbo is deigned to have linear air coming into it, so the spiral would just reduce its efficiency, Im sure it will work, but there is definitely room for improvement in most of the home brewed system I see on this site.....
